TORCS for MorphOS? Open Source Racing game
    weiseb
    Posts: 210 from 2003/3/29
    @BSzili
    At least the Return to the Roots bounty is reached now :)
    Glad to hear you consider porting frogatto.
    I would chip in with a few bucks on that as well.
  • »01.06.13 - 07:59
    Yasu
    Posts: 1724 from 2012/3/22
    I would chip in for a Frogatto port. I like that game (on AROS)!
    My MorphOS blog
  • »13.07.13 - 17:37
    defender
    Posts: 248 from 2011/4/24
    I took a google look at frogatto - it reminds me of Super Frog. If that is right i would gladly throw some Euros in for a bounty! :-o
    (It would be nice if it runs on my Powerbook)
  • »13.07.13 - 19:06
    BSzili
    Posts: 559 from 2012/6/8
    The PowerBook sounds like a reasonable target. Actually a silent upgrade Mac Mini should be enough to run it too. The key thing is the VRAM here, because there's no way in hell I can get it to work with less than 64 Meg :-D
  • »13.07.13 - 20:02
    Yasu
    My have a R9600 with 128 meg VRAM så I'd be glad to test it. And later play it :-D
    My MorphOS blog
  • »13.07.13 - 23:26
    Yasu
    Btw, is this portable? :)
    http://www.openttd.org/en/
    My MorphOS blog
  • »14.07.13 - 00:52
    Senex
    Posts: 498 from 2003/2/17
    @Yasu
    Well, in the past there have been MorphOS Versions available already.
  • »14.07.13 - 06:34
    BSzili
    I'm looking for someone with a machine with 64 meg VRAM to do a little testing. What is the maximum texture size for TORCS which is still playable with 64 meg VRAM? I mean no glitches and hitches due to running out of VRAM, not just the framerate.
  • »04.10.13 - 18:24
    BSzili
    I was thinking about which game could make use of the newly added texture compression support, and it occurred to me: TORCS. It has some large textures, especially for the terrain, and thus suffered badly from blurry textures on the most common MorphOS hardware.
    I'll merge my changes with the latest version (1.3.6), and recompile it with the latest SDK. Buckle your seatbelt.
  • »27.07.15 - 12:53
    diezi7
    Posts: 167 from 2005/7/26
    Very good news BSzili !
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »27.07.15 - 14:38
    BSzili
    Well, this didn't exactly work out. Unfortunately the texture compression produces artifacts in the textures.
  • »27.07.15 - 19:32
    BSzili
    I just tested OpenJK too, and the texture compression still produces artifacts there. It looks like MorphOS 3.9 didn't fix all of the texture compression issues :\
  • »01.08.15 - 08:20
    BSzili
    Just to confirm, the texture compression artifacts are still there on higher mip levels in 3.10.
  • »30.05.18 - 15:28
