id Software to release Doom 3 source code
    Posts: 110 from 2020/12/24
    Uploaded a new release with shaders enabled.
    Two executables this time: The "_alt" version is for those with gfx issues (never enable EAX sound with it).
    I would not go too crazy with a 64mg vram: 640x480 and low settings preferable.
    For a "normal" game now better set r_renderer ARB as shaders still not there for this game among other issues. You can enable r_useTripleTextureARB for bumpmapping/specular that kinda works with it (of course no r_usedrawinteraction0 enabled -> just for R200 gfx for now).
  • »16.03.23 - 17:02
  • ghh
    ghh
    Posts: 60 from 2017/7/15
    Doom3 ProjectUAC_r6_4 "alt version"
    https://youtu.be/Igxpvdx4Y94
    PowerMac G5 DC 2.3GHz, Radeon X1950Pro 256MB Pci-e
    The "normal version" works well, but without mlook.
  • »16.03.23 - 22:51
    beworld
    Posts: 683 from 2010/2/10
    Try :
    r_skipPostProcess 1
    I try that and magical .... no more FPS at 1 :-)
    Dont known if we lost detail GFX with this option
    koszer a écrit :
    Cowcat wrote:
    Lots of questions....
    https://www.youtube.com/watch?v=RlOZN-hrx3k
    That's how this version looks on my machine (FullHD, Details set to Ultra, all advanced functions are on):
    https://youtu.be/JlvsVvjY5wo
    The game runs quite well (15-20 FPS) until there's some unsupported object in sight (like glass, or fire). Then the FPS gets down to about 1.
    My MOS ports
  • »10.04.23 - 13:29
    Posts: 1360 from 2004/2/8
    beworld wrote:
    Try :
    r_skipPostProcess 1
    The details are lacking one way or another. But with this option we certainly gain some visual effects that would otherwise be a black blob and some speed too.
    Here is how the timedemo works with and without r_skipPostProcess 1:
    WITHOUT (watch out, painful to watch):
    https://youtu.be/qqe8RDWBCtU
    WITH (typed during the first seconds of the video):
    https://youtu.be/EI7g7KULroY
  • »10.04.23 - 16:37
    Tcheko
    Posts: 544 from 2003/2/25
    What was the rendering resolution?
  • »11.04.23 - 06:22
    r_skipPostProcess 1
    This comes down to an issue I asked many moons ago but seems to be a forgotten email....
    And for what I check now, it "could" be also related when effects as
    doublevision/berseker/grabber, etc are applied (probably others).
    r_skippostprocess is checked in draw_common.cpp/RB_STD_DrawShaderPasses. After that if renderer is ARB2, copyframebuffer is called.
    That function ("copyframebuffer") is in image_load.cpp.
    At image_load/copyframebuffer, opengl functions (readbuffer, copyteximage2d, etc) are called: Something's going on with those.
    Ok. What it has to do with doublevision/grabber and so ?
    Well, at game/PlayerView.cpp, those visual effects call "capturerendertoimage".
    At rendersystemsystem.cpp is were capturerendertoimage is located and what it does is flag commandId with "RC_COPY_RENDER".
    Further down the line the check for commanId is at tr_backend.cpp/RC_ExecuteBackEndPrograms.
    When "RC_COPY_RENDER" is checked in the loop, it calls RB_CopyRender. And RC_CopyRender calls "copyframebuffer".
    So now we have two places were copyframebuffer does "wrong" whatever ARB render is in use.
    Edit: Postprocess also affects all renders.
    [ Edited by Cowcat 11.04.2023 - 13:37 ]
  • »11.04.23 - 07:02
    1920x1080
    Details set to: Ultra.
    Advanced options:
    High Quality Special Effects - Yes
    Enable Shadows - Yes
    Enable Specular - Yes
    Enable Bump Maps - Yes
    Vertical Sync - Yes
    Antialiasing - 16x
  • »11.04.23 - 08:12
    Tcheko
    koszer wrote:
    1920x1080
    Advanced options:
    Vertical Sync - Yes
    Antialiasing - 16x
    Ha. Maximum stress settings.
    How much FPS at 800x600 (about 4x less pixels) or 1024x768 (about 3x less pixels)?
    15 fps is barely enjoyable for playing imo.
  • »11.04.23 - 14:10
    beworld
    here i have 800x600 20-60 FPS :-)
    My MOS ports
  • »11.04.23 - 14:37
    For those trying D3 with new MOS 3.18 and have issues with mouse/menu/gfx the fix is not really there:
    As I suspected from and old debug beta done from someone with a beta 3.18 SDK, game recompiled with new SDK works now for supposedly all machines that were problematic.
    And I don't really know why the f new SDK fixes that :)
    Anyway working on for another release.
    PS: Does game now looks better with shader render with new MOS upgrade ???
  • »14.05.23 - 06:19
    Here's a video of timedemo1 on the latest dhewm3 version (and gfx card drivers public release 9):
    https://youtu.be/97T2iJ0rRE0
    I can see some new effects (like sparks). Some slowdowns are gone, but I believe some new were found :)
    The starting screen acts weird (with discoloration problems on buttons, and the incoming Mars seems to be missing us by a fair margin).
  • »19.08.23 - 07:04
    @koszer
    And latest r6_5 ? Only one binary. It should fix almost all problems witn menu/intro mars: On some machines forward button + fire gets "nulled", but rest kinda works.
  • »22.08.23 - 06:52
    Posts: 478 from 2019/5/9
    Please what machine is used?
    Is it yours Powermac G5 Quad + Radeon X1950GT ?
  • »22.08.23 - 09:01
    Yep, that's my QUAD.
  • »22.08.23 - 10:56
    Cowcat wrote:
    @koszer
    From what I've checked the menu glitches are gone. But I've managed to run the r6_5 only after a few failed attempts. I'll do some more testing soon.
  • »23.08.23 - 03:53
    @thread
    I installed last doom3 from morpos-storage.
    Tested on Pegasos 2 1.33 GHz + Radeon 9800 and Sam460LE + Radeon X1950 XT.
    Port is very fast - on Sam 15 FPS with timedemo !!
    But, graphics is not good by default, ligths has squared shadows, all very bright and yellow. If I look at above youtube videos, there is normal graphics.
    By default there are no .cfg file in archive.
    - in log there is:
    ARB2 renderer not available
    using ARB render system ... this explains poor graphics
    Please, what is recommended config. And what renderes are available?
    Also, on morphos-storage there is written that archive is version r6.5, but in the log there is dhewm3 1.5.3pre version. Is this right?
  • »23.11.24 - 09:42
  • vox
    vox
    Posts: 616 from 2003/11/24
    I have Doom 3 on Steam and iMac G5 abeit with 1.5GB RAM
    What to do to test Doom3 MOS?
  • »23.11.24 - 19:03
  • vox
    vox
    SoundSquare wrote:
    i don't see the point in harassing bigfoot to port a game that won't run at more than 15fps on any current morphOS hardware.
    And this game sucks anyway.
    I have played all the Dooms, including Doom reboot and Doom Eternal.
    And Doom 3 (esp Doom 3 BFG edit) is best horror experience and true DOOM recreation
    as horror doom (but not as fast paced FPS).
    So keep your opinion for yourself.
    Didnt HunoPPC proven you wrong? At least on OS4?
    https://oldschoolgameblog.wordpress.com/2022/07/09/doom-3-for-amigaos-4-has-been-released/
  • »23.11.24 - 19:18
    Posts: 12556 from 2003/5/22
    No, he didn't, because a statement made in 2011 (i.e. half a decade before X5000) using the word 'current' refers to 2011, not to 2022 and beyond.
  • »23.11.24 - 19:49
  • vox
    vox
    OK what kind of performance can I expect on iMac G5, not on X5000?
    And how to get the latest MOS exe? Since I do have data files for latest classic Doom3
    as well as of BFG edition (if that can be used).
  • »23.11.24 - 20:56
    > what kind of performance can I expect on iMac G5 […]?
    I have no idea.
    See comment #70.
  • »23.11.24 - 21:17
  • vox
    vox
    I have no idea.
    See comment #70.
    Its funny I did post it, but to make peoples life easier, I ll repost it
    https://github.com/Cowcat5150/dhewm3/releases
  • »23.11.24 - 21:22
    - in log there is:
    @sailor
    If ARB2 is not available, Doom3 reverts to non-shader rendering.
    Funny: A couple of weeks ago, shaders worked on my R300 system. Now you say that, and the same happens with me here: No shaders with SDL2 2.30.7 or 2.30.9. So now I don't know wtf is going on.
    Archive version is not related at all to dhewm3 source version.
  • »24.11.24 - 08:01
    Figured out that D3 needs to be recompiled with new 2.30.9 SDL2 for the shader issue.
    And I got to update stuff too.
  • »24.11.24 - 09:49
