id Software to release Doom 3 source code
    Posts: 1344 from 2004/2/8
    IKE wrote:
    What are your system specs? Thanks!
    It's Power Mac G5 QUAD (4x2,5 GHz) with Radeon X1950GT.
  • »24.05.22 - 12:12
    Cool_amigaN
    Posts: 776 from 2011/11/30
    Don't know where to report it and whether it's affiliated with the issues regarding tinygl you are discussing here, but Quake 3 Arena suffers from textures falling in various maps (not the default ones though). For example OSP CTF2 (Crossing Paths), on the centre place where there should have been fog, there are white boxes instead. Tried to take a grab via builtin Quake III grabber but graphics appear heavily scrambled on the image. If needed I can shoot a photo. This is happening to a lot of custom maps such as Short Circuit (DM map) - I can list some more if needed.
  • »25.05.22 - 20:10
    Posts: 110 from 2020/12/24
    @Cool_amigaN
    Quake3: My guess is new TinyGL vs old Q3 MOS port (and mods behaving badly).
    You "could" test my warpos Q3 port and check out what does (I have to upgrade it btw):
    https://github.com/AmigaPorts/ioq3
    Run the latest release (beta9r4) from a shell after adding "stack 0x2000000".
    Of course backup the old Q3 MOS binary and configs.
    Even being out of this thread, help is help. You can PM me about it (or bigfoot).
    [ Edited by Cowcat 26.05.2022 - 08:14 ]
  • »26.05.22 - 05:13
    Cowcat wrote:
    er because skipLightScale is "0": Sometimes newer compiled versions tend to reset some of the values (config is rewritten with default values).
    The weird gfx glitch I don't know now.
    I've set the skipLightScale to 1, it's better this way.
    The glitch is gone. Probably moon phase has something to do with that :)
    here's a new YouTube video
    Now - the game runs well, but as soon as our character takes a hit (gets shot or hit in hand-to-hand combat) the game stutters for a while. It makes the difficulty level much higher, even more when we're engaging multiple opponents (video to come).
  • »26.05.22 - 09:23
    @koszer
    Did you check your email ?
    Moon ?
    Also Mars positioning has something to do with game running ok. A lot of gremlins.
  • »26.05.22 - 11:21
  • rob
    rob
    Posts: 142 from 2008/7/22
    Doom 3 is currently on sale on steam for £0.99 until 7th of July for anyone wanting to get a legal copy of the data files.
  • »01.07.22 - 04:04
    tolkien
    Posts: 556 from 2013/5/29
    I have instaled latest r6 release with second update of TinyGl in my G5 9600Pro
    I fails mouse and manus as you know.
    But If I run with r_renderer ARB2 option the game shows the same text from the console in the window and I can only exit to Ambient.
  • »06.09.22 - 16:04
    @tolkien
    It's weird.
    As said, for the mouse/menu bugs looks like a symptom as the "rogue" version in r5 release: That one had little changes there and added new OpenAL lib. Supposedly it was compiled with SDL2 2.0.20 as the normal doom3 binary (or whatever SDL that was around at those times).
    Worked for me not for the rest ( not macmini ).
    Maybe OpenAL new lib has something to do ??? The only way is to put back the old and reinstate the changes I did at the time for it to work.
    As for the renderer ARB2 option probably the gl calls to shader programs aren't the same as SDL2 <=2.24 have in their gl wrapper. I see some working about that in new SDL2 for new tinygl.
    Test if old r5 version also crashes with ARB2 option.
    [ Edited by Cowcat 06.09.2022 - 21:29 ]
  • »06.09.22 - 18:28
    beworld
    Posts: 664 from 2010/2/10
    To active new functions of tinygl (sharders), you need new SDL2 (TinyGL53 branch), actually i working on it... (I test and I give feedback to bigfoot)
    I rebuild R6 with my SDL2 beta, i see some errors with shaders but ARB2 is available...
    i reactive SDL_SetWindowGrab and i dont see any problem with that here (G5 X800)
    Need more test i think...
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »07.09.22 - 03:33
    @beworld
    Enabling SDL_SetWindowGrab fixes the bugs mentioned ? Wonder why is needed for some gfx cards and not others. And why having it disabled was working before (in r5).
    Instead of compiling neo/sys/morphos/glimp.cpp, it's ok to use neo/sys/glimp.cpp (at least it works for me).
  • »07.09.22 - 06:19
    bigfoot
    Posts: 510 from 2003/4/11
    Cowcat wrote:
    @beworld
    I recently fixed some code in SDL that might be related.
  • »07.09.22 - 07:25
    beworld
    this fix is present into SDL 2.24.0 release present on morphos-storage
    My MOS ports
  • »07.09.22 - 08:36
    tolkien
    @Cowcat
    Just tested r5 with same result trying r_renderer ARB2.
    Uploading an img RQ75NRx
  • »07.09.22 - 15:02
    @tolkien
    Naaa... forget it until the new special SDL2 library shows up.
    Meanwhile I uploaded a new r6 release. Fingers crossed.
  • »07.09.22 - 18:06
  • IKE
    IKE
    Posts: 150 from 2009/11/7
    @CowCat @BigFoot @BeWorld
    OK, I finally got a chance to try everything out. I updated to Dhewm r6_2, TinyGL 9/4/2022 update and SDL 2.24.0.
    The graphics are becoming smoother and I was able to make it to the first safe spot on the bridge with the Soul Cube (you can see this in the video when I turn around).
    I recorded this video to show how the graphics behave when the Soul Cube is activated:
    https://m.youtube.com/watch?v=d4WkIoS4y_w
    IKE
  • »08.09.22 - 00:05
    eastone
    Posts: 47 from 2007/8/4
    Papiosaur wrote:
    @CowCat
    i have tried new r6-2 but always the same problem, mouse seems to be not supported...
    Your mouse is just unsupported. Try another one.
    PS
    The port is quite playable (23 fps at 640x480 and 21,5 fps at 800x600) on g4 1.5ghz and ati9650
    Mouse ADX AFPH0219 works very well :)
    PS2
    Readme says that timdedemo does not work but it does at least on my config.
    [ Edited by eastone 09.09.2022 - 17:15 ]
  • »09.09.22 - 12:02
    @Papiosaur
    Are menu gfx issues fixed at least ?
    Can you try it with other system ? I know you're testing on G5 with X1950 Pro.
    Any problems with some other SDL2 programs out there released recently ?
    Question:
    How many of you still with issues with new r6_2 ?
    Edit:
    eastone says unsupported mouse: Why now and not before ?
    I can speculate about that and that's why I wrote try other recent SDL2 compiled programs.
    @eastone
    I fixed all demo stuff failing but no new Readme by now.
    [ Edited by Cowcat 09.09.2022 - 16:04 ]
  • »09.09.22 - 12:49
    Papiosaur
    Posts: 2479 from 2003/4/10
    @Cowcat :
    >no unfortunaly but maybe it's a problem of TinyGL ?
    Yes my mouse was supported before.
    > Yes i will try
    > No others problems here
  • »09.09.22 - 13:36
  • ghh
    ghh
    Posts: 60 from 2017/7/15
    Doom3 ProjectUAC_r6_2
    https://www.youtube.com/watch?v=hbDnxzUlb6M
    Right: PowerMac G5 DP 1.8GHz, Radeon 9600Pro 128MB AGP
    Left: PowerMac G5 DC 2.3GHz, Radeon X1950Pro 256MB Pci-e
    SDL_2.24.0 Libraries
    TinyGL-Update-2022-09-08
    On the Radeon X1950 machine, mouse movement does not work, only when you hold down the mlook key you can move the figure forward and backward. I have two identical mice.
  • »09.09.22 - 19:12
  • IKE
    IKE
    Just FYI - I had no mouse issues with the 9650 with all the above latest updates
    IKE
  • »09.09.22 - 19:25
  • ghh
    ghh
    https://www.youtube.com/watch?v=O9Il3-xvIGs
    PowerBook G4 1.67 GHz, Radeon 9700M 128MB
  • »10.09.22 - 15:48
    bigfoot
    Ouchie, that's a pretty bad framerate. Any chance I could get you to send me an email with instructions on how to reproduce this scenario? I'd love to check out why the performance completely tanks.
  • »12.09.22 - 11:34
  • IKE
    IKE
    @Bigfoot
    The Artifact (Resurrection of Evil) when activated in the game is meant to slow everything down so you can pass or complete some task among other uses. I would say that part is normal. The problem is that the graphics are inverted upside down with a mirror image when you activate it.
    https://doom.fandom.com/wiki/The_Artifact
    edit: The Soul Cube is similar to the Artifact and what it is called in the original Doom 3.
    [ Edited by IKE 12.09.2022 - 18:47 ]
    IKE
  • »12.09.22 - 13:34
