WipeOut Port
    Posts: 1074 from 2003/3/24
    Here ist a rewrite of the original WipeOut Code. It's SDL2 based maybe someone could Port it to MorphOS?
    https://github.com/phoboslab/wipeout-rewrite
  • »27.08.23 - 08:28
    Posts: 107 from 2020/12/24
    Maybe...
  • »28.08.23 - 05:23
    beworld
    Posts: 664 from 2010/2/10
    I tried to compile it but without much success because it uses OpenGL3 functions. But I found a fork with an OpenGL legacy so in opengl1: https://github.com/mrneo240/wipeout-rewrite
    Also today, the author fixed some problems with the color palette (BigEndian problem), result:
    https://ibb.co/zZrQjJm
    Too much transparency and some wrong colors again.... no perfect...
    [ Edité par beworld 29.08.2023 - 08:48 ]
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »28.08.23 - 17:21
    beworld
    Progress !! all colors are now OK
    https://ibb.co/2KN4RZB
    My MOS ports
  • »30.08.23 - 15:41
  • ASiegel
    Posts: 1386 from 2003/2/15
    eliot wrote:
    Looks great. But where are advantages compared to the original Amiga version?
    Technically, it's a different game.
    "Wipeout 2097" is the sequel to WipeOut.
  • »30.08.23 - 20:41
    Tcheko
    Posts: 539 from 2003/2/25
    Nice :) I hope you'll be able to do a release soon.
  • »31.08.23 - 05:48
    beworld
    done
    https://www.morphos-storage.net/?id=1942392
    i put all data.... if any problem with, i delete then ;-)
    My MOS ports
  • »31.08.23 - 09:12
    BSzili
    Posts: 561 from 2012/6/8
    EDIT: Ok, this gives an idea for the changes:
    https://github.com/phoboslab/wipeout-rewrite/blob/master/README.md
    They are two different games:
    https://en.wikipedia.org/wiki/Wipeout_(video_game)
    https://en.wikipedia.org/wiki/Wipeout_2097
  • »31.08.23 - 14:36
    BSzili
    BeWorld deserves all the credit, I'm only providing moral support 😅
  • »31.08.23 - 16:42
    Flash
    Posts: 106 from 2019/11/1
    Great port, it works very well under Macmini (silent upgrade version) and I have still to try under my Pegasos 2.
    Beoworld rocks!
  • »01.09.23 - 04:11
    beworld
    Tchecko found a bug when exit the game with a special "developer" configuration.
    (mode debug into MorphOS boot)
    I resolved this bug, i re-upload archive soon
    My MOS ports
  • »01.09.23 - 06:17
    waldiamiga
    Posts: 95 from 2007/7/25
    Thanks for your work! Today I will test on iMac G5 and PowerBook G4.
    MorphOS.pl
    Alienware 15 R3|WinUAE 5.x/AmigaOS4.1x & Icaros Desktop 2.x & QEmu 9.x.x
  • »01.09.23 - 10:30
    DrMaybe
    Posts: 17 from 2018/6/3
    It's an excellent game that works well in window mode but not fullscreen mode. In fullscreen mode, the screen flickers and is very slow.
    The system is macmini.
  • »03.09.23 - 15:49
    beworld
    MacMini 32M VRAM ?
    I just test with my Macmini 1.5 64VRAM, and no problem here....
    My MOS ports
  • »03.09.23 - 16:40
    Tcheko
    Are you using Enhanced display? This features is quite VRAM expensive. Might help here to disable if you're using it.
  • »03.09.23 - 17:53
    DrMaybe
    macmini 1.25Ghz 32MB VRAM.
  • »03.09.23 - 17:55
    DrMaybe
    Yes! I am using enhanced mode, but turning it off does not change anything. BTW. The opening animation at the beginning is slow too.
  • »03.09.23 - 18:02
    Tcheko
    The slowness you're experiencing is typical of a low VRAM situation.
    If you're using an image as a background in Ambient, you an also replace it by a solid color that will take 0 bytes of VRAM instead of some MB.
    You can also try to start the game from S:user-startup.
    As the game won't return immediatly, Ambient will not be loaded until the game exits saving quite some VRAM in the process.
    But the real question is in fact how much VRAM needs WipeOut for textures... Beworld? Any hint about that ?
  • »04.09.23 - 05:13
    beworld
    Test on my IMac:
    Before launch game: 34MB used/128MB
    In game: 52MB/128MB
    So 18-20MB, i think....
    My MOS ports
  • »04.09.23 - 08:36
  • man
    man
    Posts: 136 from 2019/11/11
    i m not sure but you can change the graphic card to pc one flash in mac os
    or
    you make a tower with a mac radeon card
    obligement certainly for help
  • »04.09.23 - 11:32
  • man
    man
    no it s certainly for g4 cube perhaps idon t remenber
  • »04.09.23 - 11:41
