Space Cadet Pinball for MorphOS
    Primax
    Posts: 190 from 2021/7/2
    beworld schrieb:
    @primax ok, which game ? SpaceCadet and possible to have crash log ? via logtool (send PM)
    Just tested again: Could quit the games without any problems.
    Perhaps I should have rebooted first after installation of the fixed sdl libraries before testing the games.
    Thanks for the games and keep on going! :)
  • »01.12.21 - 14:25
    Templario
    Posts: 549 from 2012/4/28
    The table of records doesn't work and the F2 key neither.
  • »02.12.21 - 15:40
    beworld
    Posts: 664 from 2010/2/10
    @templario
    Working with software renderer (executable unless .hw)
    With hw menu/text options are disabled.
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »02.12.21 - 17:57
    Templario
    beworld escribió:
    @templario
    Thank you for your explanation, I play with the hardware version, because with the software not works.
  • »03.12.21 - 13:49
    Mozzerfan
    Posts: 100 from 2016/10/5
    Hi Beworld,
    I tried to install the newest sdl2 libraries on my sam460 and now space cadet pinball crashes again. All is ok on my ibook g4 and macmini. Is this an altivec problem again ?
  • »09.02.22 - 10:22
    beworld
    mmmm strange, i check that.
    Thanks for report.
    My MOS ports
  • »09.02.22 - 14:22
    beworld
    Ok i reupload archive with fix.
    You right again altivec... i missing update my github... :(
    My MOS ports
  • »09.02.22 - 16:36
    Mozzerfan
    It's working again. Many thanks Beworld.
  • »09.02.22 - 17:52
