e-uae and uae4all
    bash64
    Posts: 977 from 2010/10/28
    I have no sound in these two apps.
    I use rhLaunch to start e-uae.
    No other app has an issue with sound.
    Any ideas?
  • »11.11.10 - 04:44
    bash64
    I decided to run it from the shell.
    Still no sound.
    Here is the output from e-uae proving it found the ahi device:
    2.APPS:E-UAE_0.8.29-WIP4> e-uae -J 1 -w -1 -0 as.adf
    E-UAE 0.8.29-WIP4
    Build date: Mar 28 2007 20:39:48
    Opening cfgfile '.uaerc'...failed
    Bad joystick mode specification. Use -J xy, where x and y
    can be 0 for joystick 0, 1 for joystick 1, M for mouse, and
    a, b or c for different keyboard settings.
    Timebase frequency: 33.290001 MHz
    Rexx port "UAE" installed.
    Resetting frame rate hack
    Building CPU table for configuration: 68000 prefetch 24-bit addressing
    1866 CPU functions
    Building CPU function table, 44736 opcodes (0 1 1).
    AppWindow started.
    AMIGFX: Using a 24-bit true-colour display.
    Sound driver found and configured for 16 bits stereo at 11025 Hz, buffer is 4410 bytes (ahi.device)
    reset at 0
    PAL mode, 50Hz (h=227 v=312)
    chipmem cleared
    Illegal instruction: 4e7b at 00fc0564 -> 00fc0582
    SERIAL: period=372, baud=9600, hsyncs=16 PC=fc2234
    MOTORDELAY! fc49a8
    PAL mode, 56Hz (h=227 v=275)
    warning: program is doing blitpri hacks.
  • »15.11.10 - 01:45
    bash64
    Resolved.
    Now....I am not sure how anyone would know that to switch to advanced settings for their AUDIO device in the preferences tool that they would have to switch a checkmark in the pull down menu that says 'list view' or 'panel view'. I think that 'basic' and 'advanced' settings would be a better way of wording it. After having found the ADVANCED settings (list view) for the audio device I was able to set ALL of the AHI music units to the same sound card and then I got sound. 'list view' is not very intuitive, well, nmaybe to a MUI programmer, but not to a user.
  • »15.11.10 - 02:32
    Posts: 12577 from 2003/5/22
    I'm really puzzled as to what you mean by "advanced settings". There's nothing like that there. MorphOS has 'Audio' prefs as well as 'Sound' prefs, both which can be easily reached in list view as well as in panel view. For panel view see:
    http://jpv.wmhost.com/morphos2_review/pics/04-prefs.png
    'Sound' is in the first row, 'Audio' is in the last row.
    AHI knows only one single music unit.
  • »15.11.10 - 08:03
    bash64
    I see your point.
    However, until I opened list view and changed all of the units 0-3 and set them to the same driver (some were apple, some were sound blaster) I could not get audio working for e-uae. I am not sure which unit e-uae tried to use. From what I remember only unit 3 was set to sound blaster and the rest remained apple.
    Oh well. It is fixed. On to the next issue....
  • »15.11.10 - 15:21
    > I see your point.
    I have my doubts about that.
    Again: It has zilch to do with list view versus panel view. As you can see from the image I linked to, 'Audio' prefs can be accessed in any view mode. There is nothing hidden when using panel view.
  • »15.11.10 - 16:06
    klapdeur
    Posts: 132 from 2003/6/28
    can someone help me with rhlaunch the site is down at im looking for it.
    klapdeur
  • »16.09.11 - 15:29
    xyphoid
    Posts: 870 from 2008/7/11
    How do you config 2player stick/joypad
  • »16.09.11 - 16:17
