Warsow - no server list
    mt12345
    Posts: 72 from 2011/4/4
    I click 'join game' then 'search' but nothing shows up.
  • »17.07.11 - 18:39
    mt12345
    :-( nobody plays Warsow?  :-(
  • »20.07.11 - 13:23
    Divinity
    Posts: 532 from 2009/9/8
    where is It ?
  • »20.07.11 - 19:52
    Posts: 12577 from 2003/5/22
    > where is It ?
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7072&forum=10&start=1
  • »20.07.11 - 20:04
    pampers
    Posts: 1073 from 2009/2/26
    How hard is to post straight link instead of clicking 2 times to get into link? I think it would take less time.
    MorphOS 3.x
  • »20.07.11 - 21:14
    I think you're mixing up the agents of two different propositions here :-P In case you're question is meant to read "How hard is to post straight link instead of making others click 2 times to get into link?" let me answer: It wouldn't be hard at all. But just because something isn't hard doesn't mean I'll do it ;-)
    It wouldn't have taken me less time to post a direct link.
  • »20.07.11 - 21:52
    Jambalah
    Posts: 820 from 2008/3/30
    And how did you managed to run it?
    Everything stops with the same error I found in the old thread
    Initializing Shaders:
    ERROR: Could not find any shaders!
    Sys_Error: Could not find any shaders!
    Something is missing.... Or I'm missing something...?!?
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »21.07.11 - 05:23
