1941 Extreme Deluxe for MorphOS Released!
    _DaNi_
    Posts: 154 from 2010/5/4
    1941 Extreme Deluxe Morphos is available for download, ported from OS4 to MorphOS with several new feactures, like new reworked Backdrops called High Backdrops and original Backdrops. New weapons, new sound fx´s, new bitplanes and a lot of new fun stuff for all.
    IMPORTANT:
    1941 Extreme Deluxe README
    A Gift for XMAS to all MorphOS users and fans
    DOWNLOAD from MOS2DEPOT:
    1941 Extreme Deluxe MOS
    DOWNLOAD from AMINET:
    1941 Extreme Deluxe MorphOS
    [ Editado por _DaNi_ el 2010/12/15 11:27 ]
  • »14.12.10 - 20:24
    SoundSquare
    Posts: 1214 from 2004/12/1
    nice effort.
  • »15.12.10 - 06:06
    _DaNi_
    thanks, is a fantastic game and fastastic port to morphos with a lot of hard work, optimized to the limits for work on all MorphOS machines :)
    enjoy!!!
  • »15.12.10 - 09:30
    waldiamiga
    Posts: 96 from 2007/7/25
    Good work. Thanks !
    MorphOS.pl
    Alienware 15 R3|WinUAE 5.x/AmigaOS4.1x & Icaros Desktop 2.x & QEmu 9.x.x
  • »15.12.10 - 15:16
    xyphoid
    Posts: 870 from 2008/7/11
    FATAL: cant load image data/backgroundHigh/back7.jpg: JPEG loading error
    didn't work for me
  • »17.12.10 - 00:04
    Krashan
    Posts: 1107 from 2003/6/11
    Definitely the port hasn't been seriously tested. I fails here on Pegasos 2 with very similar error, just "back5.jpg" is reported as problematic ("JPEG loading error"). The file seems to be OK, it loads into any image viewer/editor.
  • »17.12.10 - 05:48
    JohnFante
    Posts: 163 from 2006/9/4
    No problem here. Works very well.
    I had som problems downloading the file the first evening it was up (would stop at 17MB), but the day after everything worked fine.
  • »17.12.10 - 07:28
    Tcheko
    Posts: 544 from 2003/2/25
    Working fine here. Slow to start and need 24bit display, if not, colors are trahsed.
  • »17.12.10 - 07:35
    Posts: 12556 from 2003/5/22
    Works fine here using this:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7461&forum=9&post_id=79983#79983
    Didn't test with older powersdl.library yet.
  • »17.12.10 - 08:19
    xyphoid
    link says it was compatable with powersdl 14 which I had downloaded 15.2 but got error
    FATAL: cant load image data/backgroundHigh/back5.jpg: JPEG loading error
    same as Krashan using 1.5 macmini 2.7 morphos
  • »17.12.10 - 11:36
    zukow
    Posts: 661 from 2005/2/9
    maybe bug in xad, did you use lha or xad ?
  • »17.12.10 - 20:41
