Posts: 1390 from 2010/1/6
Here the settings of my monitor:
http://img9.myimg.de/b18da87.jpg
You should try one of the monitor presettings like 64khz-monitor (or similar). If it runs you may change values for H/V-frequencies and bandwith (MHz) proper to your monitors values.......that is the normal way keep a monitor running with AOS or MOS.......
I've seen there is a small problem with image hosting.....if an error occours follow the link in the error massage......
[ Editiert durch Amigaharry2 an 2010/5/15 17:00 ]
