CAMD.LIBRARY REPLACEMENT FOR MOS !!!
    Kokos
    Posts: 26 from 2009/10/27
    Thanks!
    I'll try later.
    Meanwhile, maybe someone knows something about native lib. :)
  • »05.05.10 - 06:01
    Golem
    Posts: 766 from 2003/2/28
    Have a look here. Should work with Pegasos and SBLive hardware.
  • »05.05.10 - 11:27
    Kokos
    I'm working on Mac Mini.
    I see only OS4 version of camd.library on this site..
  • »05.05.10 - 11:34
    Golem
    Mhh... right, that was just the 68k library with some new hw drivers... and as far as I can tell that is exactly the same version that was on MDC. So give it a try, grab the BnP archive here. Or hop on irc (#morphos irc.freenode.net) and someone could probably provide you with the archive from MDC.
  • »05.05.10 - 11:59
