Quake any version on MOS
    athlon
    Posts: 4 from 2003/5/17
    Will it play with on morph OS? :-?
  • »15.09.03 - 17:25
    hooligan
    Posts: 1948 from 2003/2/23
    Q1 and Q2 both work just fine.
  • »15.09.03 - 17:53
    Miky060
    Posts: 694 from 2003/2/24
    ...it seems there is also a MOS version of QuakeII but it is not public. Not "YET" I hope :-D
  • »15.09.03 - 19:58
    warface
    Posts: 653 from 2003/2/24
    And in addition the Heretic II port by Hyperion using the Quake II engine runs smoothly as well.
  • »16.09.03 - 06:21
    Bifford
    Posts: 283 from 2003/2/24
    hiya
    QII refuses to install here: the stupid installer doesnt work with my size HD. Because it is a big HD installer wraps the size and quake thinks i have just 512mn space free and says it needs 550.
    sigh. tried 3 installers, they all do the same (including NG). So I dont get to play QII.
    Biff
    Bifford the Youngest
  • »16.09.03 - 16:06
    redrumloa
    Posts: 1424 from 2003/4/13
    How did you get it to install? It locks up here right after I put in the PC disk :-?
  • »16.09.03 - 17:06
    Wishmaster
    Posts: 342 from 2003/6/29
    Install it by hand without the installer.
    Simply copy all needed files to the desired destination.
    Pegasos PPC
  • »16.09.03 - 20:26
    warface
    What kind of "PC" disk?
  • »18.09.03 - 06:46
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP on 2011/1/29 7:56 ]
    Pegasos2 G3, 512 megs RAM
  • »19.09.03 - 12:43
    homer
    Posts: 17 from 2003/6/13
    very high framerate-
    ok right whatever you need to know what frame rate is first . I can say with all certainty its not doing true 15 frames per second or faster. Still im glad your having fun. If this isnt trouble, dam redifne trouble now too.no trouble means not having to do what you did. :-)
  • »20.09.03 - 02:41
    Posts: 979 from 2003/6/28
    Homer, what are you talking? your english seems be more bad than mine ( too bad ), where live you ?
    Or your english is very bad, or you have 12 years old or something or i dont know...
  • »20.09.03 - 03:56
    Wishmaster
    If you call that trouble simply buy a playstation and learn english.
    Pegasos PPC
  • »20.09.03 - 07:50
    Posts: 261 from 2003/3/13
    About QUAKE2, there is a MOS version, i have
    it, but it doesn't support network/multiplayer
    and it's software 3d :(
    Then there is a amiga exe warpos i believe,
    but it doesn't work on my peggy, and then
    there's hyperions port, wich works perfectly :)))
    I did need to manualy copy the pc cdrom baseq2
    drawer to enable multiplayer client/server.
    And i quess if you like network multiplayer,
    a paystation won't help much..
    Bye,
    Felix.
  • »20.09.03 - 13:25
    porneL
    Posts: 49 from 2003/7/16
    tested quake1 for morphos. runs at 26 fps in 800x600.
    (and morphosduke 0.3 finally worked for me [works too fast :D])
    if you have problems with quake1 run it with -safe
    this text is here to confuse you
  • »20.09.03 - 23:59
    homer
    well its typos oh never mind was talking to my friends at yahoo at the sametime. But still the comment stands its not true real "25 fps" unlees its fields per second on a pegasos. I only jope he is making what I am thinkin he is making . The problem is the sooner done the sooner your ahead of everyone else.
  • »21.09.03 - 00:56
