hello everyone, need some help here getting Eve to run right. when i start it, it starts in a wierd resolution. See the Eve logo in the right border, start is in right bottom corner, and my screen don't seem to be able to auto sync. Since my screen don't have any resize apps i can just move the picture around. How do i fix this? does my modeedit has anything to do with it?
Hi, eVe currently uses an 800x600x32 display resolution. Make sure you have a compatible mode available. Future releases will support several different resolutions and windowed mode too.
are you saying 32bit 800x600? how do i config that in morphos? in system settings i can only choose from 8bit, 15/16bit and 24bit, is this a manual job? do i need to edit some tekst files to get this to work?
