MAME 0.88 released
    Posts: 916 from 2004/1/24
    Quick thread to let you all know that MAME has been updated to version 0.88.
    Get it here:
    MAME 0.88
    Thanx Fabien!
    [ Edited by Stevo on 2004/11/3 16:24 ]
  • »03.11.04 - 13:23
    Posts: 979 from 2003/6/28
    Not in news?
  • »03.11.04 - 18:07
    magnetic
    Posts: 2129 from 2003/3/1
    Woohoo!
    Fab is the man!
    or is it THE Fab
    :-o
    Will the REAL Fab please stand up?
    magnetic
  • »04.11.04 - 04:47
    Frostwork
    Posts: 302 from 2003/4/18
    Oooooh, yeah!
    Thank you very much!
    And even sooner than xmame ;)
    cheers,
    frostwork
  • »04.11.04 - 10:45
    Mi-Go
    Posts: 95 from 2003/9/18
    It's really cool! :)
    I've got only one problem: it doesn't recognize symultaneous keypresses, while on linux everything works fine... any help?
    M.
  • »05.11.04 - 07:16
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    That's weird, i never noticed that here. What key combination does not work for example ?
    Here i can play some sf2 games with keyboard and do all special moves, so that means something. ;)
  • »05.11.04 - 08:43
    Fab, what about 7-zip support? There are some unofficial MAME versions supporting it, and there are a good SDK at http://www.7-zip.org
  • »05.11.04 - 08:53
    Mi-Go
    So, made some tests on both OSes and here's the result:
    xmame 0.86 -on debian-
    all works fine
    mame 0.88 (and 0.84 as well) -on mos-
    - working (symultaneous keypress ok): last blade 2; marvel vs capcom (partially, only if you press strong punch +strong kick to switch characters)
    - not working: samurai shodown IV; garou mark of the wolves; vampire savior
    guess you figured out I'm a beat 'em up fan...  :-D
  • »05.11.04 - 23:11
    Jupp3
    Posts: 1193 from 2003/2/24
    Does it happen even if you map arcade buttons to different keys?
  • »06.11.04 - 08:49
    maurensen
    Posts: 358 from 2003/10/3
    Another good work!
    10x Fabien!!!
  • »07.11.04 - 16:48
    analogkid
    Posts: 711 from 2004/11/3
    great work, Fab.
    are you planning to add the extended GUI to 0.69 ?
  • »07.11.04 - 21:37
    Velcro_SP
    Posts: 929 from 2003/7/13
    Is the latest version of MAME the best for a MorphOS user with a G3 Pegasos, or is there an earlier version that might work more responsively?
    Pegasos2 G3, 512 megs RAM
  • »08.11.04 - 07:56
  • Fab
    Fab
    I would say, the older it is, the faster it is, regarding mame core. However regarding mos specific sources this is the contrary. :)
    Between 0.37 and 0.88, i think the speed has halved, while morphos code has been improved. This is the price of a better emulation and readability i guess.
    Anyway, with a G3, if you want to get the maximum speed, i suggest you use an older version.
    Maybe i'll add my latest changes to older versions, if i find them. :)
  • »08.11.04 - 08:35
    tokai
    Posts: 1289 from 2003/2/25
    I usually keep all versions installed, some games work better with this version other games with that version. :-)
    Also sometimes older roms become incompatibel with newer mame versions. So you need to get/create a new romset for the new mame version from same game.
    regards,
    tokai
  • »08.11.04 - 20:12
    Uhm, what about modify old mame versions for support newer romsets? :)
  • »09.11.04 - 06:10
    tokai
    timofonic: äh?
    Was that a serious question?
    When you modify mame to support newer ROM sets.. what will be the result?
    Yes, a new MAME version.
    And as you can see this happens already all the time. :-)
    What is required is Pegasos with G4 1.3GHz or better and altivec support in MAME. I want to play Souldblade with full fps! ;-)
    regards,
    tokai
  • »09.11.04 - 08:39
    @tokai
    And full hardware 3D support for latest radeons & full OpenGL support ;-)
    I was mean same games but supporting newer roms of those games :P
  • »09.11.04 - 09:58
    @tokai
    WHY???
  • »09.11.04 - 13:23
    Mi-Go
    Yes, and appearently there's no logical reason.
    For example, in Marvel vs Capcom, combinations like MPunch+MKick (to call the 3rd char) or SPunch+SKick (to switch chars in your team) work with no problems whatever the key config; instead none of the supers that involve pressing 2 punches/kicks at once work.
    Moreover, in the testing screen double presses are recognized at once...  :-?  :-?  :-?
  • »09.11.04 - 15:28
    aliem
    Posts: 85 from 2003/12/11
    I have the same problem: mame doesn't recognizes 3 key pressed simultaneously.
    :cry:
  • »13.11.04 - 17:49
  • Fab
    Fab
    Ok, i'll try to fix that for the next release. I think i have an idea of the problem. However could you give me a game name and a good combo combination requiring several keys, so that i test properly (for example, how to make the cooperative special move with ken&ryu in mshvc ? :)).
  • »13.11.04 - 20:21
    Mi-Go
    Samurai Shodown IV (samsho4.zip): all the supers are the same, BACK;FORWARD;DOWN;A+B (i.e the first 2 buttons... ;-))
    or, easier, just press a+b to make any character dodge
    or in garou (as you have it among the screenshots of your site) c+d in T.O.P. mode (i.e. when the character is flashing) to make a kinda special stuff
    or you could try... ok, I'l stop it here :-D
  • »14.11.04 - 00:58
