Problem with Pixeltetris port
    igracki
    Posts: 471 from 2003/2/24
    Add this to the end of Game::initialize() in game.cpp, this removes the hits.
    mPlayState = nullptr;
    mOptionsState = nullptr;
    mPausedState = nullptr;
    return success;
  • »25.11.24 - 12:55
    Papiosaur
    Posts: 2614 from 2003/4/10
    This is the log if could help:
    src/game.cpp: In member function 'void Game::exit()':
    src/game.cpp:87:9: warning: deleting object of abstract class type 'State' which has non-virtual destructor will cause undefined behavior [-Wdelete-non-virtual-dtor]
    87 | delete i;
    src/game.cpp: In static member function 'static void Game::pushNewGame()':
    src/game.cpp:131:5: warning: deleting object of polymorphic class type 'GameState' which has non-virtual destructor might cause undefined behavior [-Wdelete-non-virtual-dtor]
    131 | delete Game::getInstance()->mPlayState;
    src/game.cpp:134:5: warning: label 'Game' defined but not used [-Wunused-label]
    134 | Game:getInstance()->pushState(Game::getInstance()->mPlayState);
    src/game.cpp: In static member function 'static void Game::pushOptions()':
    src/game.cpp:140:5: warning: deleting object of polymorphic class type 'OptionsState' which has non-virtual destructor might cause undefined behavior [-Wdelete-non-virtual-dtor]
    140 | delete Game::getInstance()->mOptionsState;
    src/game.cpp: In static member function 'static void Game::pushPaused()':
    src/game.cpp:149:5: warning: deleting object of polymorphic class type 'PausedState' which has non-virtual destructor might cause undefined behavior [-Wdelete-non-virtual-dtor]
    149 | delete Game::getInstance()->mPausedState;
    ppc-morphos-g++-11 -noixemul -O2 -Wall -I/gg/usr/local/include -I/gg/usr/local/include/SDL2 -Isrc -D__MORPHOS_SHAREDLIBS -std=c++17 -DNDEBUG -D__AMIGADATE__=\"26.11.2024\" -c src/gamestate.cpp -o src/gamestate.o
    src/gamestate.cpp: In member function 'void GameState::handleEvent(Action)':
    src/gamestate.cpp:257:11: warning: enumeration value 'stay_idle' not handled in switch [-Wswitch]
    257 | switch(action)
    src/gamestate.cpp:257:11: warning: enumeration value 'back' not handled in switch [-Wswitch]
    src/gamestate.cpp:257:11: warning: enumeration value 'select' not handled in switch [-Wswitch]
    ppc-morphos-g++-11 -noixemul -O2 -Wall -I/gg/usr/local/include -I/gg/usr/local/include/SDL2 -Isrc -D__MORPHOS_SHAREDLIBS -std=c++17 -DNDEBUG -D__AMIGADATE__=\"26.11.2024\" -c src/inputmanager.cpp -o src/inputmanager.o
    ppc-morphos-g++-11 -noixemul -O2 -Wall -I/gg/usr/local/include -I/gg/usr/local/include/SDL2 -Isrc -D__MORPHOS_SHAREDLIBS -std=c++17 -DNDEBUG -D__AMIGADATE__=\"26.11.2024\" -c src/main.cpp -o src/main.o
    ppc-morphos-g++-11 -noixemul -O2 -Wall -I/gg/usr/local/include -I/gg/usr/local/include/SDL2 -Isrc -D__MORPHOS_SHAREDLIBS -std=c++17 -DNDEBUG -D__AMIGADATE__=\"26.11.2024\" -c src/menustate.cpp -o src/menustate.o
    src/menustate.cpp: In member function 'virtual void MenuState::update()':
    src/menustate.cpp:86:27: warning: comparison of integer expressions of different signedness: 'int' and 'std::vector<Button*>::size_type' {aka 'unsigned int'} [-Wsign-compare]
    86 | if (index < mButtons.size()-1)
    src/menustate.cpp:67:16: warning: enumeration value 'stay_idle' not handled in switch [-Wswitch]
    67 | switch (mInputManager->getAction())
    src/menustate.cpp:67:16: warning: enumeration value 'back' not handled in switch [-Wswitch]
    src/menustate.cpp:67:16: warning: enumeration value 'move_left' not handled in switch [-Wswitch]
    src/menustate.cpp:67:16: warning: enumeration value 'move_right' not handled in switch [-Wswitch]
    src/menustate.cpp:67:16: warning: enumeration value 'drop' not handled in switch [-Wswitch]
    src/menustate.cpp:67:16: warning: enumeration value 'rotate' not handled in switch [-Wswitch]
    src/menustate.cpp:67:16: warning: enumeration value 'hold' not handled in switch [-Wswitch]
    src/menustate.cpp:67:16: warning: enumeration value 'pause' not handled in switch [-Wswitch]
    ppc-morphos-g++-11 -noixemul -O2 -Wall -I/gg/usr/local/include -I/gg/usr/local/include/SDL2 -Isrc -D__MORPHOS_SHAREDLIBS -std=c++17 -DNDEBUG -D__AMIGADATE__=\"26.11.2024\" -c src/optionsstate.cpp -o src/optionsstate.o
    src/optionsstate.cpp: In member function 'virtual void OptionsState::update()':
    src/optionsstate.cpp:93:16: warning: enumeration value 'stay_idle' not handled in switch [-Wswitch]
    93 | switch (mInputManager->getAction())
    src/optionsstate.cpp:93:16: warning: enumeration value 'drop' not handled in switch [-Wswitch]
    src/optionsstate.cpp:93:16: warning: enumeration value 'rotate' not handled in switch [-Wswitch]
    src/optionsstate.cpp:93:16: warning: enumeration value 'hold' not handled in switch [-Wswitch]
    src/optionsstate.cpp:93:16: warning: enumeration value 'pause' not handled in switch [-Wswitch]
    src/optionsstate.cpp: In member function 'void OptionsState::changeGhostBlock(OptionsState::SettingChange)':
    src/optionsstate.cpp:233:35: warning: suggest parentheses around '&&' within '||' [-Wparentheses]
    233 | if ( s == SettingChange::left && config::ghost_piece_enabled || s == SettingChange::right && !config::ghost_piece_enabled)
    ppc-morphos-g++-11 -noixemul -O2 -Wall -I/gg/usr/local/include -I/gg/usr/local/include/SDL2 -Isrc -D__MORPHOS_SHAREDLIBS -std=c++17 -DNDEBUG -D__AMIGADATE__=\"26.11.2024\" -c src/pausedstate.cpp -o src/pausedstate.o
    src/pausedstate.cpp: In member function 'virtual void PausedState::update()':
    src/pausedstate.cpp:79:27: warning: comparison of integer expressions of different signedness: 'int' and 'std::vector<Button*>::size_type' {aka 'unsigned int'} [-Wsign-compare]
    79 | if (index < mButtons.size()-1)
    src/pausedstate.cpp:60:16: warning: enumeration value 'stay_idle' not handled in switch [-Wswitch]
    60 | switch (mInputManager->getAction())
    src/pausedstate.cpp:60:16: warning: enumeration value 'back' not handled in switch [-Wswitch]
    src/pausedstate.cpp:60:16: warning: enumeration value 'move_up' not handled in switch [-Wswitch]
    src/pausedstate.cpp:60:16: warning: enumeration value 'move_down' not handled in switch [-Wswitch]
    src/pausedstate.cpp:60:16: warning: enumeration value 'drop' not handled in switch [-Wswitch]
    src/pausedstate.cpp:60:16: warning: enumeration value 'rotate' not handled in switch [-Wswitch]
    src/pausedstate.cpp:60:16: warning: enumeration value 'hold' not handled in switch [-Wswitch]
    src/pausedstate.cpp:60:16: warning: enumeration value 'pause' not handled in switch [-Wswitch]
    ppc-morphos-g++-11 -noixemul -O2 -Wall -I/gg/usr/local/include -I/gg/usr/local/include/SDL2 -Isrc -D__MORPHOS_SHAREDLIBS -std=c++17 -DNDEBUG -D__AMIGADATE__=\"26.11.2024\" -c src/piece.cpp -o src/piece.o
    src/piece.cpp: In constructor 'Piece::Piece(int, int)':
    src/piece.cpp:7:18: warning: '*this.Piece::piece_type' is used uninitialized [-Wuninitialized]
    7 | p_piece_type = piece_type;
    src/piece.cpp:8:16: warning: '*this.Piece::rotation' is used uninitialized [-Wuninitialized]
    8 | p_rotation = rotation;
    ppc-morphos-g++-11 -noixemul -O2 -Wall -I/gg/usr/local/include -I/gg/usr/local/include/SDL2 -Isrc -D__MORPHOS_SHAREDLIBS -std=c++17 -DNDEBUG -D__AMIGADATE__=\"26.11.2024\" -c src/renderer.cpp -o src/renderer.o
    ppc-morphos-g++-11 -noixemul -O2 -Wall -I/gg/usr/local/include -I/gg/usr/local/include/SDL2 -Isrc -D__MORPHOS_SHAREDLIBS -std=c++17 -DNDEBUG -D__AMIGADATE__=\"26.11.2024\" -c src/state.cpp -o src/state.o
    ppc-morphos-g++-11 -noixemul -O2 -Wall -I/gg/usr/local/include -I/gg/usr/local/include/SDL2 -Isrc -D__MORPHOS_SHAREDLIBS -std=c++17 -DNDEBUG -D__AMIGADATE__=\"26.11.2024\" -c src/texture.cpp -o src/texture.o
    ppc-morphos-g++-11 -noixemul -O2 -Wall -I/gg/usr/local/include -I/gg/usr/local/include/SDL2 -Isrc -D__MORPHOS_SHAREDLIBS -std=c++17 -DNDEBUG -D__AMIGADATE__=\"26.11.2024\" -c src/utilities.cpp -o src/utilities.o
    ppc-morphos-g++-11 src/board.o src/button.o src/config.o src/game.o src/gamestate.o src/inputmanager.o src/main.o src/menustate.o src/optionsstate.o src/pausedstate.o src/piece.o src/renderer.o src/state.o src/texture.o src/utilities.o -noixemul -Wall -L/gg/usr/local/lib -lSDL2_ttf -lSDL2_mixer -lSDL2_gfx -lSDL2_image -lSDL2 -lc -lm -lGL -o Pixeltetris
    ppc-morphos-strip --strip-all Pixeltetris
  • »26.11.24 - 11:21
