Posts: 2220 from 2003/2/24
Papiosaur wrote:
Magnycours tracks (HD, LD, SD)
Were there VGPHD versions of this track? The VGPHD project didn't cover all the original tracks IIRC.
Monaco tracks (HD, LD, SD)
Sepang track (HD, LD, SD)
These are 3rd party tracks that aren't from the VGPHD project. So there's only one version of each available and they're not with "HD" textures.
Upload of differents versions soon...
Would it be better to include all versions in a single archive? Because in your VirtualGP2-HD_1.06.lha archive there are VGPHD (HD res) versions of most original tracks, but then you still have non-HD versions of elkhartlake, magnycours, monaco, nuerburgring, and zeltweg tracks. The VGPHD project didn't cover all the original tracks and then there are these non-HD 3rd party tracks too.
So, my suggestion is to create just a single archive where you have all the original tracks without touching them, and then all VGPHD tracks in separate directories with different names, and of course the three 3rd party tracks too. Then users don't have to re-launch the game when they want to try tracks with different textures etc., and they can get everything with a single download.
For example, leave the original Barcelona track to the "barcelona" dir, and create "barcelona_ld", "barcelona_sd", and "barcelona_hd" directories for VGPHD tracks. Then edit the config/circuiti.config file to contain all these directories and they appear to the game for users to select them.
Here's my
circuiti.config file if you want to check that.
