Posts: 777 from 2011/11/30
Alright, some new results:
e-uae must definetely be set to
joyport0=joy0
joyport1=joy1
For 2 player games via joystick to be launched correctly.
This implies that Joystick Port should be configured as Port 0 and Port 1 on usb MorphOS's Prefs.
No other setting or combination has worked in any config or game that I tried (I am not counting games that can be played between joystick/mouse/keyboard. Just joystick vs joystick).
I think above info should be explicitely noted on MorphOS's Library Guide at the very end where it mentions e-uae.
Second thing, does actually e-uae supports more joyports than 0 and 1?
I can't get Dynablaster or OverTheTop to work on 3 or 4 way multiplayer, although I have setup correctly new joysticks on Port 2 and 3 on MorphOS's usb prefs (at least I get Atomic Bomberman to work but idk if it uses lowlevel lib).
Anyhow, I can't find anywhere this sort of info anywhere. Some hint or clarification would be much appreciated. Think that jPV tried in the past multiplayer on e-uae but didn't get far, if I remember correctly.
Hope there is a workaround on this. Now that we have dual displays, MorphOS counts as a tournament machine on Amiga parties :)
[ Edited by Cool_amigaN 20.06.2020 - 22:31 ]
