Hydra Castle Labyrinth problems
    Solo_Kazuki
    Posts: 194 from 2006/7/23
    Hello
    Sorry that it's me again, but it's kind of bugreport.
    I'm using newest SDL2 (from 4th May) and newest version of HCL for SDL2.
    I cannot use OGG music, only MIDI works ok.
    When I'm changing music type (OGG/MIDI) also music volume is changing.
    When i'm trying to change volume, XBRZ option is changed.
    When cursor is set to XBRZ nothing is changing.
    XBRZ setting is ommited and I must turn off this option again every time i'm running game.
    BTW: What functions are set to joypad buttons? Because not all buttons have functions (at least at beginning) and some functions are not available (e.g. inventory, good that i have [ENTER] set to one of joypad buttons).
    [ Edited by Solo_Kazuki 05.05.2020 - 19:04 ]
  • »05.05.20 - 14:59
    Posts: 847 from 2007/10/23
    By the way there are still XBRZ bugs...
  • »06.05.20 - 09:05
    Solo_Kazuki
    For me this XBRZ is a bug itself...
  • »06.05.20 - 09:33
    beworld
    Posts: 683 from 2010/2/10
    Solo_Kazuki a écrit :
    Hello
    Hello
    Ok i see an issue with options, i fix that
    I see bug with a lot of thing.... same as OGG music...
    For input, i check that.
    [ Edité par beworld 06.05.2020 - 16:07 ]
    My MOS ports
  • »06.05.20 - 12:00
    beworld
    Well... after somes debugs, i fix all little bugs.
    I prepare and upload new bin.
    BeWorld
    My MOS ports
  • »06.05.20 - 16:16
    Solo_Kazuki
    Everything is fine now, except one switch in options. When You try to switch XBRZ game will suspend. I don't care about this bug because i'm not going to use XBRZ at all, but it might be disappointing to someone who want use this filter.
  • »07.05.20 - 05:28
    beworld
    When you change XBRZ, just wait a second, game freeze some second (depand of your CPU)
    but no crash here.
    My MOS ports
  • »07.05.20 - 06:04
    Solo_Kazuki
    I was waiting about five minutes and i don't thing that switching this option cause pause for more than five minutes.
    It seems that's specific for my configuration. But as i wrote before i don't care for this switch.
  • »07.05.20 - 14:53
    beworld
    OK :-)
    My MOS ports
  • »07.05.20 - 14:56
