joystick settings giana's return
    amiga4001
    Posts: 454 from 2006/11/16
    Goodday,
    Me and my daughter want to play giana sisters return.
    With a joystick offcourse!
    Now my joystick works ok in euae but there is no firebutton working in giana's return.
    All directions work except fire.
    Anybody got this too work?
    I did found out that giana is on port 1 and euae on port0.
    I can't find an error in settings of usb device..
  • »03.09.15 - 18:20
    defender
    Posts: 249 from 2011/4/24
    I have played Giannas Return with a competition pro usb. It has 4 buttons
    the little on the left side works as firebutton.
  • »04.09.15 - 17:32
    amiga4001
    Thanks!
    Using the competetion joystick now.
    Bad joystick btw but works..
  • »05.09.15 - 03:36
    Posts: 846 from 2007/10/23
    e-uae? giana's return is native morphos, isn't it?
  • »05.09.15 - 17:50
    amiga4001
    Yes it is native but was testing the joystick in euae.
  • »06.09.15 - 05:17
