Posts: 1619 from 2012/11/9
Hi Eliot,
Thanks for pointing out that Hollywood needs the plugin to play ogg vorbis audio files. MorphOS is supposed to be able to recognise ogg files by default, so I don't understand why it needs the plugin. I'm confused
I installed the plugin anyway, and that seems to fix the ogg files problem, so thanks, but if MorphOS is supposed to be able to handle ogg files, through Reggae I believe, then why can't it do it 'automatically' without the use of a plugin?
Then there's the issue of the files not loading WMV files even though MPlayer can handle them in MorphOS, but there is no direct MOS method for the program(s) to manage the files through the Hollywood player it seems, but I suppose I will just install all the Hollywood plugins as well, and hopefully that will solve these issues.
