Porting games
    pampers
    Posts: 1073 from 2009/2/26
    > Is Fraggle still around here?
    Sad if true:
    http://amigaworld.net/modules/news/article.php?storyid=7293&start=20#94081
    That's the worse news I could hear :( Did anyone confirm that?
    MorphOS 3.x
  • »10.01.15 - 09:22
  • ASiegel
    Posts: 1399 from 2003/2/15
    Very sad. My deepest condolences.
  • »10.01.15 - 09:58
    WB_Coder
    Posts: 66 from 2014/5/1
    Sad if true:
    I confirmed it, and yes it is very sad, but very true.
    WB_Coder = Wanna Be Coder
  • »23.01.15 - 02:05
    hooligan
    Posts: 1948 from 2003/2/23
    It's always the good guys who go first :-(
  • »23.01.15 - 03:28
    Posts: 168 from 2004/11/18
    Just to say that flighing high, XTR are running fine with full details with E-UAE jit. It's the same for Alienbreed3d2 and nemac4...and 68060 demos...just cool ;-)
  • »23.01.15 - 20:15
    Cool_amigaN
    Posts: 777 from 2011/11/30
    @acepeg
    Can you please post your uaerc file? Also what's your hardware config? Did you run the games on whdload slaves?
  • »23.01.15 - 20:36
    No whdload for flying high, i use WB3.1, XTR use whdload. For 68060 demos it's needed to change processor emulation on .uaerc some demos wants only a 68060 for some dark reasons.
    Sample .uaerc for 66mips on a mac mini g4 1.33ghz on G5 2.5ghz you can expect more than 100mips easily.
    # path to filesystem (replace with proper path if needed)
    filesystem=rw,Workbench3.1:PROGDIR:HardDisks/Workbench
    filesystem=rw,Jeux:Work:Jeux/AMIGAS-HD
    # path to kickstart file (replace with proper path if needed)
    kickstart_rom_file=PROGDIR:Roms/kick.rom
    chipmem_size=8
    log_illegal_mem=no
    use_debugger=no
    immediate_blits=yes
    gfx_framerate=2
    gfx_correct_aspect=false
    gfx_width=800
    gfx_height=600
    gfx_linemode=scanlines
    gfx_fullscreen_amiga=yes
    collision_level=playfields
    fast_copper=true
    sound_max_buff=4096
    sound_latency=100
    sound_interpol=none
    z3mem_size=64
    cpu_type=68060
    cpu_compatible=false
    cpu_speed=max
    cpu_cycle_exact=false
    blitter_cycle_exact=false
    cachesize=8192
    comp_optimize=yes
    comp_constjump=yes
    comp_trustbyte=indirect (see Known issues)
    comp_trustword=indirect
    comp_trustlong=indirect
    use_debugger=no
    floppy_speed=0
    sound_output=normal
    sound_bits=16
    sound_channels=stereo
    sound_frequency=44100
    chipset=aga
    show_leds=true
    kbd_lang=fr
    # joy<n> where n is lowlevel unit in amigaos target. In SDL target it's be the enumeration order.
    joyport0=mouse
    joyport1=joy1
    # overlay display
    amiga.use_overlay=yes
    # screen type (accepted values are:public, custom or ask)
    amiga.screen_type=custom
  • »25.01.15 - 20:14
    For such results you must use Fab port of e-uae jit 1.0 the other one is twice slower !
  • »25.01.15 - 20:15
    Cool_amigaN
    @acepeg
    Thanks for your reply. In the meantime, I had figured out most of the commands that should be added in my old uaerc file. I can confirm as well that this is the 1st time that I can reach 100% emulated Amiga speed on MorphOS!
    However, I face difficulties on SWOS EURO, 95/96, 96/97 whdload (old and newer versions that contain the fix for classic amiga systems) which give me trashed sprites here and there. If you have them available, can you please check? Even the nocache command on game's info does not help. On the other hand I tried a great amount of games that work flawlessly (Lion King, Alladin, Slam Tilt, Superfor, Agony etc).
  • »26.01.15 - 08:38
    For Swos i use Hdf or ADF and the no-jit uae wich works better on some games like swos or jimpower.
    For many games the jit is working good.
  • »26.01.15 - 19:12
