Quake 3 benchmarks on PowerMac G5
    redrumloa
    Posts: 1424 from 2003/4/13
    Now that Quake 3 is working on morphO 3.6, I've run some benchmarks on my G5. Feel free to add your benchmarks. Using Piru's settings, here's what I have.
    Test System:
    Powermac g5 @ 2.0Ghz
    Radeon 9800 Pro (memory clock 270Mhz, GPU clock 297Mhz)
    Using parameters by Piru for benchmarking the driver:
    setenv TGLSYNC 0
    flushlib tinygl.library
    And under Quake 3 (All details maxed out):
    r_primitives 2
    timedemo 1
    demo four
    Results:
    640x480 - 71.8 FPS
    800x600 - 71.1 FPS
    1024x768 - 70.2 FPS
    1280x1024 - 56.4 FPS
    Somewhat strangely, my old Quicksilver 2Ghz with Radeon 8500LE benched much better than this G5. I'm guessing the current build was optimized for the G4? A G5 specific build would be nice.
    What are your benchmarks on G5?
  • »11.07.14 - 00:58
    hooligan
    Posts: 1948 from 2003/2/23
    Yes that's actually pretty poor numbers, with such low resolution as 1280x1024, only 56fps. Try tweaking the settings with cg_simpleItems "1" .. I remember this helping quite a lot in getting more fps.
  • »11.07.14 - 04:50
    bigfoot
    Posts: 510 from 2003/4/11
    I just tried with my 2GHz G5 which has a Radeon X800 currently. I booted from the MorphOS 3.6 CD, used a clean Quake 3 installation and otherwise the same TGLSYNC 0 and r_primitives 2 settings as you. I got 168 FPS at 640x480, 145 FPS at 1280x1024 and 125FPS at 1920x1080.
    The 9800 Pro will fare a bit poorer for two reasons. It is slower than the X800 (but not _that_ much slower), and the command buffer can't be DMA driven on that card. However, that should mainly affect FPS at lower resolutions, and you shouldn't be seeing such a sharp decline in FPS at such a low resolution.
    I'll try with a Radeon 9800 Pro probably later today at some point, but if I don't get to it before you can do more tests, I'd recommend doing as I did and boot from CD with a fresh Quake 3 installation and seeing how it goes. BTW, to get Quake 3 to start when booting from CD, you have to open up system prefs, go to the networking settings and press 'use' without changing anything.
  • »11.07.14 - 06:43
    Doffo
    Posts: 508 from 2010/10/14
    Ouch, I tried to run a test even on my Ibook G4 1.42ghz.
    800x600 - 40 FPS
    1024x768 - 20 FPS
    It would corrupt and go slower and slower with the audio glitching out and almost come to a hault. Eventually once you go to desktop its has lines/artifacts all over, but once you run or open up windows it fixes itself up and normal again. Other games play well with no graphical errors. I will have to try on my mac mini later to see what numbers it does.
    YUUUP!
  • »12.07.14 - 18:14
    bigfoot
    A bit later than I had hoped, but I finally tried the Radeon 9800 Pro in my G5, which should make my config equal to yours. Here are my results:
    640x480: 143.5 FPS
    1280x1024: 98.4 FPS
    1920x1080: 83.9 FPS
    However, I noticed something that might explain the difference. You say your card has a 270MHz memory clock and a 297MHz core clock. At least according to the GraphicsBoards utility, my card has a 338MHz memory clock and a 378MHz core clock. My numbers are inline with what to expect from a Radeon 9800 Pro, where as your numbers are below that of even a Radeon 9800 SE.
    GPUReview link
    Is your card a genuine card or a reflashed one? If it's a reflashed one, it might have been flashed with a firmware that sets it up like some sort of Radeon 9800 SE, which would drastically impair its performance, just like you're experiencing.
  • »14.07.14 - 11:33
