Posts: 777 from 2011/11/30
Hi, here's my feedback:
I downloaded the game data files from your link and copied inside the executable. When I double click "Fade2Black" I get the following console output:
game.initLevelData 0
If I wait while it loads the data files from my HD (roughly 20 secs), the game starts (EA/DSI/Intro splash cinematic etc) and the console output adds:
WARNING: Game::setupInventoryObjects() missing inventory object index 2!
stub.state 0
cutscene.load 47
When ingame I get the following console message in infite loop:
WARNING: Game::addSceneObjectToList() cameraObject not visible!
Finally, if I select the application to run in fullscreen, then the game screen goes to lower left corner while the rest remains black.
(Note that I get a similar behaviour on ScummVM whereas game's output covers only upper left corner and in some demos as well i.e. Hugi issue 37).
Regarding perfomarce I get mixed behaviour: i close areas the game runs perfectly fine and fast (surely more than 40 fps) but when facing the first enemy I get down to 5-10 fps (meaning, it's unplayable).
My system is: MorphOS 3.3. with latest PackUltimate (& updated via Grunch) + PowerSDL v.16b on a PMAC 3.1@1.6Ghz, 1.5GB Ram, 9800XT Mac Edition.
Regards,
Stefanos
