Hurrican on powerbook
    PSofosNG
    Posts: 12 from 2012/6/17
    The Forums are to express opinions and telling news if i remember correctly so to judge badly a logic opinion is rude . Thanks :)
  • »01.07.12 - 09:08
    Posts: 12553 from 2003/5/22
    > Hurrican 1.0.0.5 is out at last [...] and yes this time the best Hurrican
    > version yet ! [...] I am waiting the MorphOS version also too :)
    It's out:
    http://amigacommunity.free.fr/phpBB/viewtopic.php?topic=162&forum=2
  • »05.07.12 - 07:24
    PSofosNG
    Hurrican has a terrible bug on ice level . The graphics are sawing with tiles / lines and the music when finishing all the levels still not working :) Maybe a final version will be more Hurrican end game like :) Besides that 2 bugs the work both AmigaOS4 And MorphOS is truly awesome thanks SixK and HunoPPC :) but correct this bugs ... is a must :)
  • »22.07.12 - 08:38
    CountRaven
    Posts: 566 from 2007/12/10
    Tested it on Pegasos 2 with Radeon 9200 and it works fine.
    Tested on Powermac with Radeon 9800 it freezes on the loading screen. Any ideas?
  • »26.08.13 - 01:29
    Derringer
    Posts: 103 from 2008/8/4
    CountRaven,
    I bet the problem is your 9800 card.
    Here in PB with 9700 and a G5 with 9650 the game runs fine.
    [ Edited by Derringer 26.08.2013 - 10:49 ]
    MorphOS PowerBook G4 1,67GHz, 2GB Ram, 250GBHdd, ATI 9700/128MB
    Morphos G5 2,7GHz, 8GB Ram, 500GB Hdd, ATi Passive cooled 9800 PRO/128MB
  • »26.08.13 - 06:48
    CountRaven
    I guess this card is supported by MorphOS. As it boots ok, so why the game can not be run. Same symptom was on another PowerMac with a 9700 card.
  • »26.08.13 - 13:39
