Posts: 2047 from 2003/4/10
Kronos a écrit :
There is no TreeView in "our" MUI but for sure in the other one.
Yes, sorry, i speak about ListTree MUI class.
Thanks for your advices.
jacadcaps a écrit :
I'm afraid Hollywood will only let you access a subset of MUI's Listview features. That's because Hollywood aims to be compatible with other platforms running older MUI and as such does not support all of MorphOS-exclusive features. You might want to consider learning ObjectiveC or C.
yes, I think it would be good to learn these languages indeed. Unfortunately there aren't many examples in the SDK (ListTree for example)... If i have access to some other source code in c and objective-c for MorphOS i will learn more speed
[EDIT] Maybe, XML Viewer source code from rzookol could help me, i could try to continue his project if stopped (add edit and drag'n drop features) and begin mine project in C.
