Shell Commands/CPU
    Posts: 782 from 2007/10/23
    What does "cpu check"? Seems to be a dummy.
  • »07.08.22 - 01:54
    bigfoot
    Posts: 508 from 2003/4/11
    Correct, it doesn't do anything on MorphOS. On AmigaOS it is used to check the CPU type. For example:
    cpu check 68020 >nil:
    if warn
    echo A 68020 or better is required.
    endif
  • »07.08.22 - 12:47
