Posts: 444 from 2006/11/16
I wanted to run donalds playground with Vice to let my daughter play with it(4 years old).
I can't get it to go it freezes on me after a rightmouseclick.
The program starts up ok and the cursor is blinking.
just as soon as I use the double tapping it freezes..cursor stops blinking and proram can't be stopped.
I downloaded latest vice (2.4) but problem is still there.
Snoopium shows on startup a missing cfgvideo.lib and a missing font.
Any tips
