More on PSA
    Robert
    Posts: 331 from 2003/5/12
    Hi folks,
    Finally got my Voodoo working and I'm delighted to say that I can now
    read the time readout, which was illegible with the Radeon.
    However, I still only have the option for a screenmode upto 800x600.
    any ideas?
    Robert.
  • »17.12.03 - 19:50
    serge
    Posts: 725 from 2003/2/20
    I use a voodoo3 3000 AGP.
    I had the same proble first time I installed MOS 1.4 from scrach.
    To resolv the problem, I took my old MOS 1.3 installation and Upgraded it to 1.4. In this way, I think MOS1.4 keep screenmode settings.
    So try to install an old MOS 1.3 and then Upgrade it.
  • »18.12.03 - 10:18
    Robert
    Hi Serge,
    I'll have a bash at that tonight, cheers. :pint:
    Robert.
  • »18.12.03 - 11:16
    Robert
    Bugger! OK, tried that, now when I switch on, the Peg seems to boot OK but after the Morphos logo the screen goes black. :-?
    I'm running off the CD now.
    Tried a few reinstalls - same thing.
    And still no other options above 800x600. :-(
    Robert.
  • »08.01.04 - 21:54
    liquidbit
    Posts: 407 from 2003/10/12
    I have the same problem with my Radeon 8500.
    I created my own screen mode, but when I test it the settings the screen worked for 2 seconds and after that the screen became black... I dont know if the problem is on my monitor or on videocard.
  • »08.01.04 - 22:57
    hooligan
    Posts: 1948 from 2003/2/23
  • »09.01.04 - 05:59
  • -D-
    -D-
    Posts: 118 from 2003/5/2
    @hooligan
    AFAIK Radeons only support 24-bit modes, the higher "32-bit" actually
    refers to "bits per pixel" and is still 24-bit depth (16.7m colors). There seems
    to be a LOT of confusion and market-hype going around about this...
    Here's a reference
  • »09.01.04 - 08:40
    hooligan
    So is MOS JPG datatype really that crappy? Anyone else noticing the same behaviour? The difference is amazingly big.
    Better to mention that I have a better gfxcard and better monitor attached to Pegasos than to the pc.
  • »09.01.04 - 10:19
    realstar
    Posts: 298 from 2003/2/24
    32bit is generally 24bit with an extra
    byte for an alpha channel. I would
    suggest loading it into ImageFX or
    FXPaint and see if you get the same
    quality. Maybe your monitor and gfx
    card are just showing too much detail
    now too. ;)
  • »09.01.04 - 11:28
    Posts: 2053 from 2003/6/4
    Anyone a clue why PSA does only like 8Bit screens on MOS?
    Some other apps allow me only to select 8 bit screens as well :-(
  • »09.01.04 - 11:41
    magnetic
    Posts: 2129 from 2003/3/1
    Yeah
    Voodoo shows time correctly. Some kind of overlay problem maybe?
    Has anyone been recording and editing samples with PSA? If so please tell us how!
    magnetic
  • »09.01.04 - 20:48
    theone
    Posts: 14 from 2004/1/5
    yes that is true but with the pegasos as with other pcs you have only 8bit of vga ,where as the classic amiga has 24bit of r g b. Which is why you wouldnt show the colors so right.SO its not true png with pegasos .Use a Sgi made png and then use a pc to try and read it right, same thing as pegasos . It wont read or show the png right. To fuzzy. Sgi differnt more true colors per bits.
    The Amiga is 24bits with and extra 8bit. 8-)
    But still the card should show more then the true 2 bits per channel you are now showing. It is the driver. 8-)
  • »10.01.04 - 09:51
  • -D-
    -D-
    :lol:
  • »10.01.04 - 10:30
    Robert
    tokai wrote:
    add some bigger 8bit screenmode(s) with Systemsettings -> ModeEdit.
    It won't let me save the settings, as I've booted from the CD.
    Robert.
  • »12.01.04 - 13:48
    Robert
    Replying to myself here but just to let you know I now have PSA in 1024x768!
    Thanks people! :pint:
    Robert.
  • »03.03.04 - 13:44
    Tcheko
    Posts: 513 from 2003/2/25
    Robert,
    How did you do that?
    It will certainly be usefull for other people experiencing the same trouble as you.
    Regards.
    PS : I had the same problem sometime ago and fixed it, but I do not remember how.
  • »03.03.04 - 14:02
    Robert
    @Tcheko:
    as Tokai said further down the thread and I think Hooligan and Magnetic also gave me this advice (although I couldn't make it work to begin with - not sure why):
    You have to add some bigger 8-bit screenmodes, via ModeEdit, save, then reboot.
    What I want to know now is how to get the dual monitor thingy up and running.
    Then midi.
    But in the words of Nana Miskouri (sp?) : "One day at a time, sweet jayzuss!" :-D
    Robert.
  • »03.03.04 - 14:22
    Jupp3
    Posts: 1193 from 2003/2/24
    oh, sometimes I get just "black screen after MOS logo" when booting... The cure?
    Just remove USB memory from USB port... Don't know what's cousing it, maybe some requester or something...?
  • »03.03.04 - 20:09
