MorphOS 3.3 Problem launching WOS-PUP-68k demos
    _DaNi_
    Posts: 154 from 2010/5/4
    I dectect now on MOS 3.3 demos from encore like "SULACO" or "BYNIGHT" full working on 3.2 mos don´t work now with mos 3.3 (i don´t know the problem) and with old app/demos too.
    Any can test it ?
  • »12.10.13 - 09:18
    Posts: 12085 from 2003/5/22
    > with old app/demos too. Any can test it ?
    I tested both Encore demos on 1.5 GHz Mac mini with MorphOS 3.3. By Night works fine here in both window mode and screen mode. Sulaco doesn't work at all, regardless of the selected mode, and crashes the whole OS/machine so that I must reboot.
    I have tested neither demo with any other MorphOS 3.x version but I remember that both demos worked fine here on MorphOS 2.4 after they got an update to v1.1:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=6550&start=22
  • »12.10.13 - 10:44
    _DaNi_
    Yes andreas, with 3.2 mos i don´t have any problem with this demos 100% working but not with mos 3.3, strange. Bynight here STOP on part 2 and Sulaco don´t launch, i need to reboot
  • »12.10.13 - 11:04
    > mos 3.3, strange.
    Yes, strange indeed, especially given that 3.3 is just a minor bugfix release.
    I can confirm this. Machine/OS crash happens later on in the demo. I just didn't wait long enough when I first tried.
  • »12.10.13 - 11:22
    _DaNi_
    Is very strange i think this release have broken? or a bug with gfx driver?.
    BIGFOOT is the solution :)
  • »12.10.13 - 11:38
    bigfoot
    Posts: 508 from 2003/4/11
    I was able to reproduce the problem By Night and fix it. The fix will be included in MorphOS 3.4. I'm fairly sure the problem you've encountered with Sulaco is the same, but I'll try Sulaco as well later and make sure it's working.
  • »12.10.13 - 14:23
    _DaNi_
    Thanks Bigfoot, you found the solution very quickly :) Is possible a solution on the fly or i need to wait for MOS 3.4?
    Thanks, test "Sulaco" and "Giana Sisters" here have problems with 3.2
  • »12.10.13 - 15:53
    Both demos work again with MorphOS 3.4. Thanks.
  • »14.12.13 - 18:47
    _DaNi_
    fantastic notice, both demos now working but "yamagi" Quake2GL, QuakeGL and RTCW did lock up and i need to reset the mac mini i don´t know if the problem id for use the MorphOS update or if is working with a clean installation, can any test this 3 game ports with morphos 3.4?
  • »15.12.13 - 10:22
