Synergy Server for MorphOS
    Elric
    Posts: 52 from 2003/4/3
    Hi!
    Very nice to read that!
    Hurry up and thanks!
    Amigan salutations!
  • »20.11.14 - 01:48
    Posts: 3004 from 2003/3/5
    Status Update:
    Mouse now moves fine over the client screen. While this may seem like a minor accomplishment, it means the backend is complete enough to allow this (including virtual space screen placement, etc).
    Coming up next: add mouse buttons and keyboard -> loading/saving of config files (gui comes later) -> first beta.
  • »20.11.14 - 12:02
    Status Update:
    Just keyboard translation missing now for the first beta to be complete. I will be updating the SynergyClient as well...
  • »26.11.14 - 05:46
    TheMagicM
    Posts: 1217 from 2003/6/17
    maybe one day the Linux version will be supported.
  • »26.11.14 - 13:55
    If you mean the server, then yes. If you mean the client: there was someone offering 50eur for me adding Linux support, but then he vaporized. I am a linux hater, so I am not installing it even as a VM without some good motivation.
  • »26.11.14 - 20:20
    Posts: 2720 from 2003/2/24
    @jacadcaps
    Nice to see these progress reports. I haven't contributed to the bounty, but I really appreciate your efforts in doing this. Synergy makes life so much easier!
  • »26.11.14 - 21:00
    TheMagicM
    aah ok. I dont use MorphOS enough to pay the equivalent of 50eu for the app. No biggie.
  • »27.11.14 - 14:14
    Yasu
    Posts: 1724 from 2012/3/22
    Is it at all possible in the future to add drag-and-drop support between different machines?
    My MorphOS blog
  • »27.11.14 - 14:36
    I do plan on adding files transfer, but d&d isn't really possible in a portable way.
  • »27.11.14 - 14:37
    Yasu
    File transfer system would also be good :-)
    My MorphOS blog
  • »27.11.14 - 19:27
    The folk who participated in the bounty just got an initial beta of the server. There's much still to be done though...
  • »16.12.14 - 06:49
    diezi7
    Posts: 167 from 2005/7/26
    Thanks for the mail with the attached beta.
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »16.12.14 - 16:01
    Cego
    Posts: 712 from 2006/5/28
    thanks!
  • »16.12.14 - 20:59
    MorphDelf
    Posts: 274 from 2004/2/20
    Hi...
    Would it be easy to port this Client or Server to AmigaOS 3.x? It would be a nice thing to control both MorphOS and AmigaOS 3.x on the same desk or will Synergy server/client be too demanding for a 68030 or a 68060 Classic Amiga?
    Just wondering.
  • »17.12.14 - 11:25
    It certainly is possible to port at least the client to 68k.
  • »17.12.14 - 14:17
    Yasu
    @jacadcaps
    Just to be absolutely clear; this would mean I could use my MorphOS mouse and keyboard to use with an Amiga, plus eventually be able to transfer files between the systems?
    My MorphOS blog
  • »17.12.14 - 15:13
    Yasu wrote:
    @jacadcaps
    Yeah, I might consider this for another bounty :) But first things first...
  • »17.12.14 - 15:21
    MorphDelf
    jacadcaps wrote:
    Yasu wrote:
    @jacadcaps
    wow. That would be really nice. My A1200 is ready for this :)
    Best Regards and a Happy Christmas to you. Thanks for the support.
  • »18.12.14 - 12:14
    Another beta was just sent out to the bounty donors...
  • »22.12.14 - 19:37
    ... aaand the bounty is now completed.
  • »04.01.15 - 11:22
