ARM for the future?
    Tcheko
    Posts: 512 from 2003/2/25
    http://www.tyan.com/campaign/openpower/
    Isn't that more sexier than those cheap ARM chips?
  • »19.10.14 - 05:50
    phoenixkonsole
    Posts: 140 from 2010/8/4
    For the saving in power consumption you could buy 4 ARM socs per year ; )
    Check Odroid XU3 it is on desktop level.
    The older U3 is already faster than a X1000 ...
    Compile FS-UAE GLES and you are done with AEONS systems.
    this is old
    http://forum.odroid.com/viewtopic.php?f=13&t=952
    http://linuxgizmos.com/odroid-hacker-board-jumps-to-faster-octacore-soc/
    x86 way to boring and PPC is dead except for special uses. Nintendo could replace the Gametablet of the WiiU with one with a 8core ARM system and stream the games from it to the wiiU -> this would be cheaper and way more modern.
  • »19.10.14 - 10:12
    Posts: 12085 from 2003/5/22
    Is UAE with PPC emulation also available for ARM?
  • »19.10.14 - 14:42
    phoenixkonsole
    I didn't checked the latest fs-UAE dev builds but dependencies are all available.
    Fs-UAE is available for arm for a long time (2years for pandora).
    http://forum.odroid.com/viewtopic.php?f=52&t=653
    Problem is that the last ppc additions haven't been commited yet into that branch.
    This could be solved If there is really interest.
    I would donate a bigger sum as soon xu3 like devices are availble for less than 100€.
    Than ppc emulation starts to make sense.
  • »19.10.14 - 14:56
    Thanks for answering.
  • »19.10.14 - 22:14
    minator
    Posts: 365 from 2003/3/28
    phoenixkonsole wrote:as soon xu3 like devices are availble for less than 100€.
    There are Android TV boxes at around $90 on ebay that should have similar performance and have a better GPU.
    Just search for "RK3288" It's a Quad A17
    The 64 bit ARM chips will probably be better at emulating PPC. They have the same number of registers which should make mapping between them easier.
  • »20.10.14 - 01:36
    phoenixkonsole
    Now the Quad A17 makes even more sense
    http://aros-exec.org/modules/newbb/viewtopic.php?post_id=90706#forumpost90706
    Any mind change regarding MOS on WinUAE?
  • »24.10.14 - 18:37
    Addendum:
    > http://www.freescale.com/files/training/doc/dwf/DWF13_APF_NET_T0795.pdf [...]
    > QorIQ LS2045P: - 4 x e5500 [...]
    > QorIQ LS3400P: - 20 x e6500
    Mentioned in http://www.powerpc-notebook.org/wp-content/uploads/2014/10/LinuxDay2014_Mi_presentation_pub_en.pdf (page 12, apparently copied from a Freescale document) for 2016 time frame:
    - LT1082P: 4 x e6500
    - LT1042P: 4 x e6500
    - LT3160P: 8 x e6500
    - LS3xxxP
  • »31.10.14 - 20:18
    > Now I get a little bit confused....ARM is relasing planning Cortex-A17 (over A12) ...
    > ....ok..A12 has no big.LITTLE...
    In order to ease the confusion, ARM has decided 2 months ago that there's no A12 anymore and has merged it into A17:
    http://community.arm.com/groups/processors/blog/2014/09/30/arm-cortex-a17-cortex-a12-processor-update
  • »29.11.14 - 20:05
    > this thing has 48 (!) 2.5GHz 64bit ARM cores. Half a Terabyte memory per chip and
    > you can gang a pair together with a coherent bus. PCIe, SATA etc is all built in.
    > Mind = boggled.
    Now available:
    http://www.cavium.com/newsevents-Cavium-Announces-Availability-of-ThunderX.html
  • »03.12.14 - 17:40
    Posts: 2720 from 2003/2/24
    > Mind = boggled.
    Now available:
    Wow! :-o
  • »03.12.14 - 20:43
    minator
    The 64-bit hardware is starting to appear now: Applied Mocro X-Gene dev board.
    Not exactly super cheap ($895 promo for the 1.6GHz version) but it's the first out there and does have 8 cores.
    There's a video here.
  • »15.12.14 - 14:18
    Yeah, definitely not cheap (and that was also a promo price), but still very interesting to see this. It's actually a full fledged desktop motherboard, 3rd gen PCI-E for real desktop GFX card, SATA 3 for HDD, etc. Eight core 64-bit CPU, up to 16GB RAM (the SoC itself supports up to 256GB RAM), etc, etc.
    This is "Samantha Done Right" (but of course this didn't exist back when Acube did the Sam)... ;-)
    Anyway, very expensive, but open for everyone to buy, no licenses, no NDA's, nothing like that. More is bound to follow, and the price is bound to come down drastically in the future for products like this.
  • »15.12.14 - 16:41
    minator
    Seen this on slashdot the other day:
    40 linux friendly single board computers
    Mostly ARM based but there's also MIPS and a few x86s in there as well. Alas not a single PPC.
    There are some they've missed, Qualcomm and Nvidia boards aren't mentioned and neither is the firefly.
    I don't think there's any 64 bit boards yet but Allwinner already showed one.
  • »03.01.15 - 15:29
    TomKeric
    Posts: 146 from 2013/2/18
    Do you think it would be realistic to do something like MOS did with the old MAC PPC´s with old iPads/iphones/android phones with this kind of more advanced ARM builds in a few years, e.g. install a future ARM-MOS version onto a phone and run it like a computer?
    (connecting your phone to a monitor/TV,Keyboard, mice is a commodity already today,
    I understand we are far from this but I just want to know if you tekkies think it is realistic?
    (Also I have noticed that tappdevices are taking larger and larger chunks of the % of webbpages visited from the clickdevices so that webbdesigners are soon in need of making tappdevice design first and clickdevices second this perhaps also need to be considered for future strategy for MOS not to get too stuck into clickdevices with their OS ?)
    -If you've never failed, you've never tried -
  • »03.01.15 - 21:10
    At least with Apple devices this wouldn't be feasible as Apple SoCs are not documented for 3rd party OS vendors.
    I don't see the connection between website design and the design of a desktop OS.
  • »04.01.15 - 08:30
    In_Correct
    Posts: 245 from 2012/10/14
    It would be nice to port to an ARM device that does not come automatically with Linux. Linux is everywhere and I hate that. But MorphOS developers would have to reverse engineer the "Apple" device. And perhaps they just shouldn't consider the "Apple" device.
    Because most website designers are stupid. They make the websites with touch screen mobile device as priority. The website renders as compatible for the touch screen mobile device, even on a desktop / laptop device. I hate touch screen device. Touch screen device loves to malfunction. And morphOS must not be reconfigured into a touch screen operating system! Certainly not like iOS, Android, or even Windows 8! Even if the mobile device has option of external keyboard and mouse / track pad they still have annoying oversized screen "buttons".
    An alternative solution should be that MorphOS support the touch screen laptop. ... The one with the traditional "click" interface and keyboard with the secondary option to touch it with a pen or stylus.
    Another alternative solution is to have device with touch screen but has the primary option of keyboard and track pad. Example is BlackBerry usually does this and the interface with keyboard and track pad which also displays a mouse arrow! :-)
  • »04.01.15 - 14:33
    >> in terms of 64-bit ARMv8 (AArch64) cores, there is announced so far:
    >> - Cortex-A53 and Cortex-A57 from ARM Ltd.
    >> - Denver from nVidia
    >> - X-Gene from Applied Micro
    >> - Thunder from Cavium
    >> - Cyclone and Typhoon from Apple
    > - Vulcan from Broadcom
    > - K12 from AMD
    - Mamba Kryo from Qualcomm
    http://semiaccurate.com/2015/01/21/name-qualcomms-64-bit-post-krait-core/
    http://semiaccurate.com/2015/01/26/roadmap-qualcomms-taipan-core-wrong/
    http://www.qualcomm.com/news/snapdragon/2015/03/02/cognitive-computing-and-custom-cpu-drive-next-gen-snapdragon-processors
    http://www.qualcomm.com/news/releases/2015/03/02/qualcomm-previews-next-generation-snapdragon-experiences-mwc-2015
    - Cortex-A72 from ARM Ltd.
    Edit: added another link
    Edit2: corrected name of Qualcomm's core and added links
    Edit3: added Cortex-A72
    Edit4: added Apple Typhoon
    [ Edited by Andreas_Wolf 01.06.2016 - 19:11 ]
  • »24.01.15 - 12:15
    minator
    - Mamba from Qualcomm
    I'd take anything from Semiaccurate with a pinch of salt!
    They can get things right but they can also get things very wrong.
  • »29.01.15 - 23:10
    ausPPC
    Posts: 543 from 2007/8/6
    http://www.raspberrypi.org/raspberry-pi-2-on-sale/
  • »02.02.15 - 19:58
    Very cool, and with a Cortex-A7 it will almost be usable! ;-) No seriously, this is a cool deal, incredible price for what you get. And Windows 10 is coming as well... :-o
  • »03.02.15 - 11:57
    Posts: 7 from 2015/1/28
    So much is happening in the ARM world right now, progress almost seem to acellerate!
    If guys decided to open source morphos, somebody could just decide to port it.
  • »04.02.15 - 09:59
    Britelite
    Posts: 66 from 2003/6/4
    Somebody could, but most likely wouldn't.
  • »04.02.15 - 10:08
