Posts: 1478 from 2012/11/10
rms,
PGS 4 runs here on several Pegasos's 2, also on Mac Mini's and also on Powerbooks without problems, so it should really run also on your config.
So what I did is, I downloaded pgs4156pro.lha from Pagestream's website, decompressed on the harddisk, deleted the content of the CSet drawer and launched it, entered my registration number and my pw and there it was, PGS 4 started without problems!
OK, I have tried a good variety of options, and the most successful is to install from scratch the PageStream archive, so now I have at last got PageStream loading -
BUT NO FONTS are loaded even though initially they show up in the lister, when I try to use one of them nothing happens, no text is input in the text fields, the cursor blinks, but does not move, and when I 'update' the font directories that are supposedly loaded all that happens is ALL the FONTS DISAPPEAR from the lister, and I cannot get any of them to show up.
When I got PageStream 4 loaded I didn't have to remove the CSets files, or disable them, they are still there in their folder, and even if I put them in a disabled folder then reboot MorphOS the same problem is still there - NO FONTS in PageStream.
Anyone any idea for a fix?
I wondered if it was a library thing, but the bullet library files have been copied across from WB3.x, which the installer initially points out, but after that there are no other prompts as it installs, but it ends up with no useable fonts.
