Posts: 12085 from 2003/5/22
> Are you saying (quoting from the v1.20 readme.txt file) that ebay are not going to be
> certfied for SSL certificates?
I don't know what the status of eBay with regard to SSL certificates is or is going to be.
> I quit OWB, and re-started it (without-rebooting) and got the same error requester on
> the same link ... BUT when I rebooted my MorphOS system, a couple of minutes later,
> if that, the error didn't come up again.
Just a guess, but maybe eBay uses different certificates on different servers and OWB was directed to another server when you tried minutes later, which opposed to the former server has a certificate that's in OWB's certificate bundle.
> it sounds like it is more likely to be an OWB issue
This may well be. I guess only Fab can tell.
> where do I get the latest MorphOS compatible version of "curl-ca-bundle.crt" file from?
> Would it be ... http://curl.haxx.se/download.html as that is now showing version 7.33.0,
> and OWB v1.20 shows version 7.28.1 of "curl-ca-bundle.crt" file [...]. I have the
> "curl-ca-bundle.crt" file that is dated the 13-April-2011 - which came with OWB 1.20, so
> I take it this is not the latest/most up to date file? However, if "curl-ca-bundle.crt" file is
> just a text file that any browser that uses the "curl-ca-bundle.crt" file then I'll download
> it as soon as you let me know.
It's not about MorphOS compatibility but about OWB compatibility. Furthermore, 7.28.1 and 7.33.0 are version numbers of
cURL, not specifically of the certificates bundle. cURL, which is the component using the curl-ca-bundle.crt file, is built into the OWB binary and can't be updated by anyone but Fab. The curl-ca-bundle.crt file is user-updatable, though. You may want to refer to this older thread (which is about Fab's OWB on OS4, though) for instructions and discussion on how to update the curl-ca-bundle.crt file:
http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=34010&forum=32#625552
> I reported "www.parcel2go.com" as being one site I could not access with OWB,
> but I think that was an "asp" issue, but in someway connected with SSL
It was first suspected to be an SSL issue, but it proved to have nothing to do with it:
https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=9174&start=10
> that has since been fixed, so of recent everything has run smoothly - a compliment to
> FAB's great work, and for that matter anyone else on the development team for OWB.
Parcel2Go now working is more a result of
Nadir's work than of Fab's.
