goa / w3d on radeon cards
    serge
    Posts: 725 from 2003/2/20
    veru happy news. Thanky very much Alain Thellier. :-)
  • »21.11.13 - 09:04
    waldiamiga
    Posts: 90 from 2007/7/25
    Yeahh. Very good information!
    MorphOS.pl
    Core i7 Notebook|WinUAE 3.x/AmigaOS4.1x & Icaros Desktop 2.x & QEmu 6.x.x
  • »21.11.13 - 14:44
    redrumloa
    Posts: 1424 from 2003/4/13
    thellier,
    Very good stuff! Much respect! :-)
  • »21.11.13 - 22:10
    Posts: 33 from 2013/6/20
    Hello folks
    It seems that "perspective texturing" dont works :-(
    I am using this command in the opengl (TinyGL) wrapper
    glTexCoordPointer(4, GL_FLOAT, 4*4,V);
    and it dont seems to works on Morphos
    (but the same code worked on WinUAE/PC version)
    It is needed as WaZ/Rp3D works in "screen space" so need a W coordinate for perspective correction
    Is there a problem in TinyGL concerning this function ???
    Is there an other function that use W coordinate (= q coordinate in OpenGL terminlogy) that works ?
    Alain Thellier
    Wazp3D-Morphos tests:
    Cow3D-68k: works 95%
    BlitzQuake-68k: works but texturing is false (= lack of perspective correction)
    TheVague1-68k: works 100%
    TheVague2-68k: works 100%
    GlExcess-Os3-68k: works but texturing is false too + coloring problems (so StormMesa2010 68k partially works :-) as GlExcess use it)
    WipeOut_2097_Demo: dont start... (problem with my WipeoutLoader usage?)
    Cube-68k: dont start
    Chromium-68k: dont start
    IhaveNoTomatoes-68k: dont start
    ... the lasts 3 are certainly lacking an SDL or ixemul version
    [ Edited by thellier 26.11.2013 - 09:20 ]
  • »26.11.13 - 09:19
    kiero
    Posts: 129 from 2003/2/28
    Hmmm, not sure if we tested use of 4 component texture coordinates. On what hardware are you running it? r200 or r300 radeon?
  • »26.11.13 - 11:09
    kiero
    blah, double post
    [ Edited by kiero 26.11.2013 - 10:11 ]
  • »26.11.13 - 11:11
    Dont know :it is a powebook g4 alu with a big screen
    Will check tomorrow
    BTW do you know if the WipeOut_2097_Demo from aminet also works on Morphos ? or only the full game version ?
    Alain
  • »26.11.13 - 12:33
    kiero
    ok, pbook is r300. no idea about wipeout demo
  • »26.11.13 - 13:32
    Intuition
    Posts: 1110 from 2013/5/24
    thellier wrote:
    Hello folks
    Alain Thellier
    Have you tried this?
    http://mos.aminet.net/package/game/patch/WipeoutLoader
  • »26.11.13 - 16:16
    Posts: 12078 from 2003/5/22
    He mentioned "WipeoutLoader usage" in posting #20.
  • »26.11.13 - 16:54
    waldiamiga
    @Alain Thellier
    Check scenedemos by Encore,that both productions require Warp3D
    Sulaco
    By Night
    MorphOS.pl
  • »26.11.13 - 20:41
    kiero
    Oh, one more thing. Are You using immediate mode or vertex arrays?
    kiero
  • »26.11.13 - 23:02
    Hello
    @waldiamiga
    Ok will test those demos
    @Intuition
    I have used the patch but perhaps it dont works with the demo WipeOut_2097_Demo
    This demo works some time on os4/wazp3D but finally crash due to the memory hit bug
    @kiero
    I am using only glDrawArrays for all drawings (see below)
    Now Wazp3D convert all primitives (like say a W3D_DrawTriFan) to triangles/points/lines list so now only the "newdraw" code is still present
    void HARD3D_DrawPrimitive(void *hc,void *p,unsigned long Pnb,unsigned long primitive)
    struct point3D *P=p;
    struct HARD3D_context *HC=hc;
    unsigned char UsePersp =(HC->state->PerspMode!=0);
    struct TexCoord4f *V=(void*)HC->V;
    unsigned int mode;
    long int n;
    HFUNC(HARD3D_DrawPrimitive);
    OS_CurrentContext(hc);
    VAR(P)
    VAR(Pnb)
    if(Pnb>MAXPRIM)
    return;
    if(UsePersp)
    NLOOP(Pnb)
    V[n].s=P[n].w*P[n].u ;
    V[n].t=P[n].w*P[n].v ;
    V[n].r=0.0;
    V[n].q=P[n].w;
    if(1.0 if(P[n].z<0.0) P[n].z=0.0;
    glTexCoordPointer(4, GL_FLOAT, 4*4,HC->V);
    else
    NLOOP(Pnb)
    glTexCoordPointer(2, GL_FLOAT,PSIZE,(void *)&(P->u));
    NLOOP(Pnb)
    PrintP(&P[n]);
    if(primitive==W3D_PRIMITIVE_POINTS) {primitive=GL_POINTS; goto newdraw;}
    if(primitive==W3D_PRIMITIVE_LINESTRIP) {primitive=GL_LINE_STRIP; goto newdraw;}
    if(primitive==W3D_PRIMITIVE_LINELOOP) {primitive=GL_LINE_LOOP; goto newdraw;}
    if(primitive==W3D_PRIMITIVE_LINES) {primitive=GL_LINES; goto newdraw;}
    if(primitive==W3D_PRIMITIVE_TRISTRIP) {primitive=GL_TRIANGLE_STRIP; goto newdraw;}
    if(primitive==W3D_PRIMITIVE_TRIFAN) {primitive=GL_TRIANGLE_FAN; goto newdraw;}
    if(primitive==W3D_PRIMITIVE_TRIANGLES) {primitive=GL_TRIANGLES; goto newdraw;}
    if(primitive==W3D_PRIMITIVE_POLYGON) {primitive=GL_POLYGON; goto newdraw;}
    newdraw:
    REM(newdraw)
    VAR(primitive)
    if(currentP!=P)
    REM(P changed)
    currentP=P;
    glVertexPointer(3, GL_FLOAT, PSIZE,(void *)&(P->x));
    glEnableClientState(GL_VERTEX_ARRAY);
    glColorPointer(4,GL_UNSIGNED_BYTE,PSIZE,(void *)&(P->RGBA));
    glEnableClientState(GL_COLOR_ARRAY);
    glDrawArrays(primitive,0,Pnb);
    return;
  • »27.11.13 - 09:08
    @kiero
    Also I tried to draw the primitive this (old & slow) way
    glBegin(primitive);
    NLOOP(Pnb)
    glVertex3f(P[n].x,P[n].y,P[n].z);
    if(UsePersp)
    glTexCoord4f(P[n].u,P[n].v,0.0,P[n].w);
    else
    glTexCoord2f(P[n].u,P[n].v);
    if(UseColors)
    glColor4f((float)P[n].RGBA[0]/255.0,(float)P[n].RGBA[1]/255.0,(float)P[n].RGBA[2]/255.0,(float)P[n].RGBA[3]/255.0);
    else
    glColor4f( (float)HC->state->CurrentRGBA[0]/255.0,(float)HC->state->CurrentRGBA[1]/255.0,(float)HC->state->CurrentRGBA[2]/255.0,(float)HC->state->CurrentRGBA[3]/255.0);
    glEnd();
    But glTexCoord4f() dont seems to exist in TinyGL as the compiler said :-/
    @waldiamiga
    I have tested the 2 demos : after starting (window/screen mode ?) they just freeze : do they need some dependancies ? (I am using a basic install from morphos cd)
    Alain
  • »28.11.13 - 08:34
    Intuition
    @Alain
    I could send you an iso image of the full game if you like?
    I gave the original CD to Karlos to help him test his BVision driver for OS4 but I'm sure he won't mind making you an iso if I ask him.
    [ Edited by Intuition 28.11.2013 - 13:10 ]
  • »28.11.13 - 14:08
    @Intuition
    Thanks Would be great to have WipeOut to test as it is certainly the most wanted war/zp3d game
    Alain
  • »29.11.13 - 17:30
    Henes
    Posts: 507 from 2003/6/14
    The Wipeout2097 demo works very fine on MorphOS. I just tried it a few minutes ago on my Pegasos2.
    AFAIR the demo has no "memory hit bug" and does not require a special loader. The illegal chip memory access is only a feature of the full game. So no need to pirate it...
  • »01.12.13 - 23:25
    Cego
    Posts: 712 from 2006/5/28
    so any update on this?
  • »21.12.13 - 11:44
    Not much :-/
    I have succeeded to make works the screenmode-requester in Wazp3D but the other problems remains (see below)
    As I have no ideas how to fix that I will release Wazp3D55 as it is (including Morphos version)
    Just give me some days to clean up the code
    I know that I promised Wazp3D for Christmas but I wanted to test it with latest Morphos3.4 : it is faster now but problems remains
    Alain Thellier
    From ReadMe:
    Beta 55
    o Bug fix about coloring (recent bug in GleXcess scene 4 )
    o OS4: Now Crisot demo "Universe#3 TheTrip" works (but without the bump-mapping effect of course)
    o Morphos: First Wazp3D for Morphos : GleXcess,Blitzquake,TheVague1,TheVague2,Cow3D,Microbe3D-demo,Nukleus-CowsNBubblesFeatVs4 demo works
    This version have software rendering and "renderer:hard" that use hardware TinyGL giving fast performances.
    W3D_MODULATE (texture coloring) dont works
    Perspective-texturing dont works because TinyGL dont know glTexCoordPointer(4,...)
    Lots of 3D progs dont works (cause unknown)
    Note: On Morphos OS4emu dont seems to emulate the Warp3D v5 functions so only old Warp3D progs may works (so Crisot demo draw nothing)
  • »27.12.13 - 10:08
    Hello & Happy New Year 2014
    Wazp3D for Morphos is NOW on Aminet
    It use TinGL as hardware renderer so people without Goa3D drivers will benefit from it
    Certainly you will be disapointed as there are not much progs that works with it :-/
    And there are lesser progs that run 100% perfect :-(
    One of the major issue is the perspective-texturing that dont works because TinyGL dont support glTexCoordPointer(4,...);
    Alain Thellier - Wazp3D
    http://thellier.free.fr/Wazp3D.htm
  • »02.01.14 - 09:18
    waldiamiga
    Yeahh, great. Happy New Year thellier.
    MorphOS.pl
  • »02.01.14 - 17:46
    Jambalah
    Posts: 820 from 2008/3/30
    Hi Thellier and thanks for your work!
    A question: I run the Wazp3D config program, doing some settngs and close the window. Nothing is saved in Envarc and nothing could be loaded from there. So when I try WipeOut, for example, a window appears with a "Loading Wazp3D.cfg" message but nothing more happens. Is it a normal beta behaviour? Thanks!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »03.01.14 - 18:18
    Intuition
    Thanks Alain!
  • »03.01.14 - 19:01
    @Intuition
    wipeout dont works = i dont know why as it works with wazp3d/os4
    wazp3d-prefs change the parameters INSIDE the wazp3d library
    then when the prog end (ie w3d_destroycontext) then a wazp3d.cfg file is saved
    that will be used next run
    this way of working ensure to never save a crashing config
    Alain
  • »04.01.14 - 07:30
