Market research for new PowerPC system
    feanor
    Posts: 104 from 2009/3/20
    Daff wrote:
    Prizes are lower on this page :
    http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MPC8610&tab=Buy_Parametric_Tab
    (it's for 1000)
    Prices for 1000 are not the same as for 100. Sure. We could probably get even lower prices than that, but the link was used to refer to the escalation of the price of the 8640D
    - Dual core CPU is useless in AmigaOS/MorphOS. So no 8640D.
    That's the wrong reason, imho, but I will note it down. And it's not useless, it's just not supported now.
    - You can do several variants : low cost with 8610/800 MHz, up to 8610/1333 MHz.
    Well, true, but I'd have to do a spread out of the several models during production. I mean if there's lots of demand for the 1333Mhz models, then I'd be left with lower-speced 800Mhz ones, and vice-versa. But yes, that's a good idea if done properly, thanks.
    Konstantinos
  • »23.09.09 - 17:50
    Posts: 564 from 2004/4/15
    Sounds very cool to me :)
    You got an email!
  • »23.09.09 - 21:12
    Crumb
    Posts: 730 from 2003/2/24
    MPC8610 sounds like a good idea. On the other hand I'm not sure if it will be much faster than my 1.5Ghz Mac Mini. And another additional and big problem is the number of years that it would take to make MorphOS available for this board.
    For the MorphOS community I think it's better to support Apple G5 machines. Some cores reach around 2.7Ghz and you can fit very nice graphic cards.
    Don't get me wrong, developing a new board sounds very nice but it would have to be twice faster than a 1.5Ghz Mac Mini for people thinking about it (specially since just the motherboard would cost them more than twice the cost of a full Mac Mini).
    Apple G5 machines reach 2.7Ghz and have 900Mhz memory bus. By the time you released that board most of people will be able to buy 2nd hand G5 hardware for very low prices.
    I understand the difference between used and new but if you develop a new board keep in mind that it should offer more than 2nd hand hardware.
    What about PPC 970 cpu family? BBRV stated the prices some years ago and the price was reasonable.
    Is it possible to get some Cell cpus?
    I would prefer PPC970 cpus... unless price is around 350Euros and performance twice than my 1.5Ghz Mac Mini.
    [ Edited by Crumb on 2009/9/23 22:37 ]
    [ Edited by Crumb on 2009/9/23 22:39 ]
  • »23.09.09 - 21:36
    mobydick
    Posts: 179 from 2004/2/26
    I've sent the mail.
    peguser.narod.ru
  • »23.09.09 - 22:36
    Posts: 12079 from 2003/5/22
    > IIRC the QorIQ have some fpu weakness.
    Regarding the FPU implementation of the P1 (and P2) "weakness" is an euphemism.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6196&forum=11&start=32
  • »24.09.09 - 04:58
    Posts: 98 from 2004/6/4
    @feanor
    Great idea! It is really right time now to switch to a newer PowerPC based mobo from a Peg2 and I will definitely pay 500eur for a MPC8640D based system. But! Always there's at least 1 "but"! I definitely need more than 1 PCI slot, SATA or IDE doesn't seems to be a problem anyway coz there's a huge amount of IDE hw here, but I have a PCI sound card which I like and don't want to change to internal one, also I will definitely need an USB and I also have a TV tuner.
    I'm using linux now much more than MorphOS because of my work and a poor development environment there, but if MorphOS will run there it would be a great thing.
    WBR, Vladimir Berezenko
  • »24.09.09 - 05:36
    The PPC970FX is available between 1.0 and 2.0 GHz, the PPC970MP between 1.2 and 2.0 GHz. The even higher clocked parts (used in the PowerMac G5, PPC970FX up to 2.7 GHz, PPC970MP up to 2.5 GHz) were discontinued by IBM.
    Actual Prices can be looked up at various distributors.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6218&forum=11&start=20#61964
  • »24.09.09 - 05:45
    Posts: 2794 from 2006/3/21
    @Crumb,
    I too would like to see the MOS Dev Team go on to working on a G5 PowerMac port of MorphOS after they are finished with the MacMini and maybe after also finishing ports to a few Mac laptop models.
    The advantage of doing it for the PowerMac is that we could use some already supported graphics cards, sound cards, etc. in the PCI slots of the PowerMac. I would hope that this would shorten the required time to port MOS to the PowerMac.
    This of course only makes sense if there isn't other better new hardware that the team should decide to port to instead. I am not hung up on buying used Macs, but their price to performance ratio as far as PPC hardware is concerned seems to be the best bang for the buck. I think it is the best option for the short term future of MorphOS, but would not be upset to be proved wrong if something better at the same price comes along.
  • »24.09.09 - 07:12
    feanor
    Actually, I tried to look up some prices for PPC970 and couldn't find a distributor, would you mind pointing to some URLs?
    Thanks
    Konstantinos
  • »24.09.09 - 07:18
    Drako^lM
    Posts: 144 from 2005/8/10
    I've sent the mail.
    Hardware :
    Power Mac G5 2.3 Ghz & MorphOS 3.18 & OSX 10.5
    Mini G4 1.5 Ghz & MorphOS 3.18
    BlaBla Team Member -> http://blabla.ppa.pl
    AmiParty Team Member -> http://www.chal.pl/
  • »24.09.09 - 07:33
    jcmarcos
    Posts: 1178 from 2003/3/13
    feanor wrote:
    jcmarcos wrote:
    just clone that MPC8610 evaluation board in you have at the smallest possible cost, that's all.
    Unfortunately that's not possible, for both copyright issues but also in terms of cost. Evaluation boards have lots of stuff that isn't really useful in an end product (like JTAG for example). Also they are quite big in size.
    I explained myself badly: Desing a completely new Mini-ITX (for example) board, taking all the knowledge from the evaluation board. Of course, those connectors for development purposes should be gone.
    By the way, it's just a shame that you have to repeat the work that NEC already did with its Redtail board. Has anybody here seen one, ever?
    I know you prefer having answers in your e-mail, but I prefer having this discussion in public, it's much more lively.
    I'm definitely not doing it for fun
    I assume you no longer work for Genesi.
    This is a market in itself. Not big, but I believe it's self sustainable
    I agree. The fact that every other player has left this market looks scary, but things can be done right.
    I don't know if a 500EUR MPC8610 board would be a right choice
    I think that's reasonable for a new MPC8610 computer, with a reasonable amount of expansion options - Yes, a single PCI slot is too little. But you have a problem: I won't buy it because my Pegasos is not broken yet. And many people will think the same: If you aren't rich, why would you buy another computer to do the same (enjoy MorphOS). Well, it's faster, but can you mention smething that us Morhers do, that needs a lot of processing power?
    the QorIQ series are the focus of Freescale right now
    Putting "freescale" and "focus" in the same sentence scares me. If I were you, I'd go for the most stablished solution, and leave others battle with freescale for newish things.
    bPlan like the idea, and I already started discussions with them about the board. I don't think I'll have a second chance in this however so I'll have to make sure it succeeds the first time.
    That looks like the start of an exciting ride!
    That's why I wouldn't like wasting their time with constant discussions and constant specs changes.
    Even if you have an exact specification in mind, things change during hardware development. Hardware usually has funny undocumented behaviours, it's a whole different world to software. With bPlan by your side, and all their expertise, many of those traps can be avoided.
    I'll have to make a decision about the hardware specs
    Use the same as your MPC8610 evaluation board.
    the project's viability and then things will start rolling.
    I guess you have a perfectly complete idea about viability, at least MorphOS wise. As for different markets, you could use again the idea of the "CrabFire", years ago: A Pegasos based firewall (running Linux, of course) that could be labelled as more secure because it used a weird (PowerPC) processor, and thus malware for it was unexistant. Sure you remember the project, it came from Gunne Steen, if I remember correctly.
    For other markets... I guess a bloody PC with Windows gets the job done easier and cheaper.
    Give us a computer for having fun! (that's why we were so grateful to Genesi anyway).
  • »24.09.09 - 09:56
    feanor
    No, only the photos posted on powerdeveloper.org.
    Hehe, actually I was never a Genesi employee, although they did fund my Altivec work on libfreevec and other stuff initially, and I will most likely work with Genesi in the future in other things as well, like ARM NEON stuff. In fact, this motherboard, if it happens it will happen with Genesi's cooperation, after all they're the ones that know how to build cool PowerPC systems and that's why I contacted them in the first place.
    Yes, that is indeed a problem that I begin to realize. Many people might complain about lack of available new hardware, but if it was there tomorrow, would they buy it?
    There are many markets, including embedded, which could be approached yes, but first I want to have an idea of how many people are interested with MorphOS/AmigaOS/Haiku/etc. In the end of October, I'll post a summary of exactly how many people sent me an email, and we can discuss it from there. I think it's a fair amount of time to make such an estimate.
    True! That's why I want to make it also! (I lied about not doing it for fun, fun is a very important factor, but it's not the deciding one, unfortunately :)
  • »24.09.09 - 10:14
    Posts: 1068 from 2003/3/24
    I would buy a board that would replace my Peg2 G4.
    But it should have at least one PCI-E and 3-4 PCI Slots.
    The 8610 would be enough for me but i would go for the 1.33 Ghz version.
    And i would be willing to pay 6-700 Euro for that board if MOS 2.x would support it.
    Oh and SATA, DDR2 or 3, GBit Ethernet, 4-6xUSB2 and AC97 should be on board. And i don't care much about the DIU.
  • »24.09.09 - 15:29
    Jambalah
    Posts: 820 from 2008/3/30
    Quote The Player!
    I would buy another PPC board more performing for that price and with that specs with no doubts.
    With MorphOS running on, of course! :-)
    Anyway it will go, congratulations for this nice idea!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »24.09.09 - 19:20
    pampers
    Posts: 1061 from 2009/2/26
    I hope your plan will come true.
    Email sent.
    MorphOS 3.x
  • »24.09.09 - 20:13
    Crumb
    @feanor
    http://www.ppcnux.com/?q=node/6562
    I've heard IBM is not as helpful with small companies as Freescale is... but a PPC970MP machine would rock :-)
    [ Edited by Crumb on 2009/9/24 22:38 ]
  • »24.09.09 - 21:35
    http://www.avnet.com offers the PPC970:
    PPC970FX between 77 and 140 USD
    PPC970MP between 209 and 315 USD
    ...depending on clock rate and quantity.
  • »24.09.09 - 22:23
    MarK
    Posts: 641 from 2004/1/25
    email sent.
    how about to make it a bit modular? first release could contain the most worth cpu, but later, you could sell a faster cpu module? like the idea of the pegasos board, where wasn't many options...
    bye, MarK.
  • »25.09.09 - 06:11
    clr666
    Posts: 85 from 2008/7/8
    For first, idea of CPU upgrade card (with extra hw connectors like DDR2, etc.) for existing Pegasos machines is not so bad ;) And it is looong expected thing.
    And whole new hardware with modern interfaces will be pretty nice after years of waiting new powerful hw from Genesi.
    _______________
    wintel free
  • »25.09.09 - 06:48
    Posts: 1516 from 2003/2/24
    @feanor
    But I will definitely fund the Haiku porting, because I like it and I think it has a lot of future.
    What kind of interest there is on the Haiku side?
  • »25.09.09 - 09:20
    Posts: 2053 from 2003/6/4
    A modular system with current SoC-like ppcs is no viable way. The 8610 and 8640 are too different alredy:
    E.g. the 10 has inbuild gfx but no LAN, while the 40 has LAN but no gfx. The 1022 is also quite different. Thus modularity would be possible with one chip only and would only offer to get different clock rates. But e.g. in the case of the 8610, here are no higher clock rates scheduled that currently available. I doubt that the effort to make it exchangeable is worth the benefit. IMHO the design should kept as simple as possible to leave the price as low as possible.
  • »25.09.09 - 09:25
    jcmarcos
    Agreed. Regular computers forgot about exchangable CPUs a long time ago. Not only for technical reasons (would you put critical, nearly gigahertz signals, on a regular copper connector?), but also because nobody changes the CPU of his computer. Moreover, the manufacturer would have to build products (CPU modules) without knowing if they are going to sell ever, and that's completely opposite to the first rules of business.
  • »25.09.09 - 10:19
    Golem
    Posts: 766 from 2003/2/28
    Huh?
  • »25.09.09 - 19:20
    feanor
    Golem wrote:
    Huh?
    He probably meant CPU *cards* and he's right about that.
  • »25.09.09 - 20:14
    SoundSquare
    Posts: 1213 from 2004/12/1
    yes, interesting question as the Haiku folks stated several time that their main concern was x86 and the PPC port is behind (and late).
  • »25.09.09 - 21:58
