Is there an equivalent to the PathPart command?
    ChrisH
    Posts: 167 from 2009/11/26
    Both AROS & OS4 have a really handy standard command called PathPart (which really should have been called AddPart). Does MorphOS come with an equivalent?
  • »09.01.13 - 11:16
    Posts: 2159 from 2003/2/24
    What does it do?
  • »09.01.13 - 13:35
    ChrisH
    Easiest to explain with some examples:
    > PathPart Foo:Bar Meef
    Foo:Bar/Meef
    > PathPart Foo:Bar/ Meef
    Foo:Bar/Meef
    > PathPart Foo: Meef
    Foo:Meef
    So basically it joins a path to a filename, taking to add (or not) a / in the middle as required.
  • »09.01.13 - 14:33
    osco
    Posts: 680 from 2009/10/20
    Would a incarnate of "Lformat" work?
    Parameters: Dir = One or more directory name(s), Keys = Display keys, NoDates = Do not display dates, To = Destination file, Sub = Subdirectories included, Since = List files since date given, Upto = List files upto given date, Quick = Simple directory list, Block = List files in block sizes, NoHead = Do not display header lines, Files = Files only, Dirs = Directorys only, LFormat = Output list using this format string, All = All files.
    list ram:#?.ps lformat "foo.rexx *"%s%s*"" to bar.bat
    Sorry ignorance but onward
  • »10.01.13 - 01:18
    Posts: 1520 from 2003/2/24
    I think point is that PathPart handles different cases properly and most likely it is just an AddPart().
    This command is missing from MorphOS but it could be implemented to future versions.
    [ Edited by itix 10.01.2013 - 09:46 ]
  • »10.01.13 - 05:45
