MUI_Disable
    ShInKurO
    Posts: 36 from 2008/5/30
    Hi all,
    I've noticed if I use MUIA_Disable to disable->enable in few time my UI then my program slow down on my powerbook with MorphOS3.1, I believe it is some kind of gfx bug.
    I use MUIA_Disable with MUIA_Window_Sleep, and in this cas slow down is very visible...
    case MUIA_Window_Sleep:
    if (data->sleep==tag->ti_Data) tag->ti_Tag = TAG_IGNORE;
    else
    data->sleep= (LONG)tag->ti_Data;
    SetAttrs(data->maingroup, MUIA_Disabled, tag->ti_Data, TAG_DONE);
    break;
    [ Edited by ShInKurO 28.07.2012 - 09:32 ]
  • »28.07.12 - 09:32
    Tcheko
    Posts: 510 from 2003/2/25
    Please, providc a source test case showing the slowdown.
  • »28.07.12 - 10:55
    Posts: 2971 from 2003/3/5
    This is user-configuration dependent - some configs will use heavy alpha blitting which is not hw accelerated on the PowerBook.
    Anyway, you should *really* refrain from using both MUIA_Window_Sleep and MUIA_Disable - this is against the standard system behavior. MUIA_Window_Sleep is for the whole window, while MUIA_Disable is for *single* objects and not huge areas.
  • »28.07.12 - 13:05
    ShInKurO
    Have you another way to propose me for implementing a sort of modal behaviour on the amiga? :)
    If you use disable you can show to user a content disabled, but he can interact with main window input yet, while sleep provides the right disable input that I want, but user is not informed he cannot use that window until he click on it... I want avoid user click on window to understand it is "disabled", he should see this status with his eyes and without to click on it...
  • »28.07.12 - 17:10
    Tcheko
    Afair, when a window is put to sleep, the mouse pointer goes for a hourglass (busy pointer) which explicitly tells the user that the window input is currently locked.
  • »28.07.12 - 18:12
    MorphOS already does this by default - the window does not have to be active for you to see a busy mouse pointer when you move the mouse above the window. Please don't try to alter the behavior of the OS in your applications - that's not up to app developers to decide. The only result is that you get an application that does not belong with the rest and therefore sticks out (in a negative way).
  • »28.07.12 - 19:36
