Cycle Custom Class and setting value array in new method
    rebraist
    Posts: 96 from 2011/4/6
    Hi!
    I created a private cycle custom class with MUI create custom class (subclassing it from cycle).
    Then i create an object with NewObject((mymcc)->mcc_Class, NULL, TAGDONE);
    If i start this way the program crashes.
    If i write this:
    NewObject((mymcc)->mcc_Class, NULL, MUIA_Cycle_Entries, myarray, TAGDONE);
    it's ok.
    But if i want to fill cycle gadget values with an external array (or even with one taken from the data area) i.e. in new method?
    I tried with a set (obj, MUIA_Cycle_Entries, myarray); but it does nothing.
    How can i do if i would like to "set" it at new time?
    Thank you!
    [ Edited by rebraist 02.03.2012 - 20:59 ]
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »02.03.12 - 18:58
    Tcheko
    Posts: 540 from 2003/2/25
    MUIA_Cycle_Entries is an attribute not settable afair.
    Also, Cycle Object list items are not meant to be dynamically updated (ie : read static list only).
    If you need to update a list of item dynamically, better go for more suitable objects like List for example.
  • »03.03.12 - 06:57
    rebraist
    thank you!!
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »03.03.12 - 07:02
