Voyager issue
    TheMagicM
    Posts: 1217 from 2003/6/17
    Is it just me or does Voyager (MOS) not work with Yahoo Mail? Seems like I cannot reply to a email.. also..when I go to morph.zone and log in it says I'm not logged in even though I have entered my username/pwd... I'm on my pc now..
  • »03.01.04 - 05:35
    DSLCC
    Posts: 246 from 2003/5/14
    Someone correct me if I get this wrong! :)
    I don't believe that Voyager works with Yahoo mail.
    The solution to the problem with logging in to MorphZone and Amiga.org
    for that matter is solved by setting the maximum size of the disk
    cache and I think the memory cache to 0. What is happening to you is
    that Voyager is reading the page from the cache instead up updating it
    from the server.
    Hope this helps!
    PS: Did you enjoy the hot weather here in TX today? :)
    David
    Pegasos 1 G3 MorphOS 1.4.5* Mac G4 Sawtooth 1Ghz Tiger 10.4.1* Both Rock! :-D
  • »03.01.04 - 06:48
    TheMagicM
    David! Hey, hows it goin? Yes, that worked! Thanks btw!
    The weather down here was humid..not hot actually..went to
    see some Rampage Hockey with my son..pretty fun stuff.
    Your Pegasos case looks good..looks like mine.
    -Alex
  • »03.01.04 - 06:55
    DSLCC
    Alex,
    Glad I could help. My memory is still working! I am learning a lot about this Pegasos! :-)
    It got up to 73F today...kindof hot for Jan 2.
    I have more pics of my Peggy at http://www.dslcc.net
    See ya!
    David
  • »03.01.04 - 07:08
