PowerPC assembly language book
    kamelito
    Posts: 103 from 2011/9/21
    Hi
    Is there any good book about PowerPC assembly language?
    What book(s) are you using the Mos Team?
    The only available PowerPC programming books I can find at Amazon are only related to 6xx family. Are they still valid for a programmer interested in G4? if yes what is the best one?
    Thanks In advance
    Kamel
  • »21.10.11 - 07:04
    bash64
    Posts: 934 from 2010/10/29
    Is F.O.R.T.H. available for Amiga?
    Thanks
    I like Assembly and basic and FORTH but I hate C and won't use it.
    Powermac G5 2.3ghz 2GB, ATI 9600 Pro
  • »21.10.11 - 13:30
    Posts: 2794 from 2006/3/21
    JForth by Delta Research
    I have version 1.2 dated Feb. 18th, 1986
  • »21.10.11 - 14:08
    Posts: 12079 from 2003/5/22
    Yes, it is. That's what Aminet has for m68k:
    http://aminet.net/package/dev/lang/F68K
    http://aminet.net/package/dev/gg/tile-forth-bin
    http://aminet.net/package/dev/lang/Jax4th
    http://aminet.net/package/dev/lang/AForth
    http://aminet.net/package/dev/lang/Forth
    http://aminet.net/package/dev/lang/cforth
    There's even one implementation for PPC (PowerUP, so should be MorphOS compatible):
    http://aminet.net/package/dev/lang/PPCcforth
  • »21.10.11 - 14:55
    mobydick
    Posts: 179 from 2004/2/26
    JForth is freeware since 1998. I don't know if homepage of JF still available ATM, but if you want, I can send you this archive.
    BTW, I tried to use JF on MOS 1.4x and I found it unusable. Not tested on MOS 2.x.
    Also, I have gforth-0.6.0 (or 0.8.0?) compiled for me by Jorge Areceda.
    [ Edited by mobydick 21.10.2011 - 19:13 ]
    peguser.narod.ru
  • »21.10.11 - 16:10
    It is, including downloads:
    http://www.softsynth.com/jforth/
  • »21.10.11 - 16:15
    kamelito
    Thx Cisc
    As for Forth maybe you can open another thread guys :)
  • »21.10.11 - 16:51
    kamelito
    Interesting link
    http://www.tentech.ca/index.php/projects/powerpc-instruction-set-quick-reference-card/
    Another good link; I've corrected some broken links for images if you're interested I can provide them.
    http://www.afturgurluk.org/mirrors/macintosh/www.lightsoft.co.uk_Fantasm/Beginners/begin1.html
    http://www.devx.com/ibm/Article/20943
    Kamel
    [ Edité par kamelito 21.10.2011 - 21:11 ]
    [ Edité par kamelito 24.10.2011 - 14:48 ]
    [ Edité par kamelito 26.10.2011 - 14:03 ]
  • »21.10.11 - 20:11
