PIPING IN MORPH?
    osco
    Posts: 680 from 2009/10/21
    IXPipe: why is the name of the Device different from Dos "Pip: ?
    Alias can it be used to make IXPipe: and Pip: seen as the same?
    :-? Osco seen reaching for the manuals
    TIA :-)
  • »07.09.11 - 08:10
    Chain-Q
    Posts: 339 from 2003/10/12
    I guess IXPIPE: behaves a bit differently to PIPE: because the former is for ixemul.library apps (POSIX ports), so it was tuned for that purpose, while PIPE: is for native API apps.
    [.Hosting AmigaSpirit.hu.]
  • »07.09.11 - 10:48
