MUI Gadget and SDL
    rebraist
    Posts: 96 from 2011/4/6
    Hi!
    I'm playing with sdl.
    Is there any way to use mui gadget or whatever mui stuff in an sdl created window?
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »06.09.11 - 08:24
    Posts: 1516 from 2003/2/24
    Nope. SDL.mcc could be cool, though.
    [ Edited by itix 06.09.2011 - 12:20 ]
  • »06.09.11 - 10:19
    rebraist
    yeah! ;-)
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »06.09.11 - 10:30
    rebraist
    i saw that in sdl_syswm.h is implemented a struct called SDL_SysWMinfo with an int data field, which should contain the window address. Does this work?
    Thank you!
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »06.09.11 - 11:44
    Posts: 2240 from 2003/2/24
    Problem is you can't (AFAIK....) put MUI-objects on just any Intuition-window, only windows created with MUI.
    So as Itix pointed out one would need an SDL.mcc, a MUI-class that interacts with SDL.
  • »06.09.11 - 14:06
