TurboPrint driver selfmade?
    igracki
    Posts: 389 from 2003/2/25
    are there any infos for writing printer drivers for Turboprint?
    I would like to have a driver for the HP PSC 2210 all-in-one printer.
    I have send an email to turboprint asking, if there will be a driver for this printer, but they
    doesn't answer since 4 weeks;-(
    There is a project at sourceforge for this printer, so it should be possible to write a driver for TP.
    Or could someone help me to port this unix printer driver?
  • »21.12.03 - 23:40
    docgeddy
    Posts: 37 from 2003/7/31
    you could disable TP, install the old printer.device from OS3.9, and write an Amiga-printer-driver
    DocGeddy
    Member of Butterfly Army
  • »22.12.03 - 19:35
    Posts: 126 from 2003/2/17
    Look at MOS SDK....
    there is a file called turboprint.doc
    It will perhaps help you :)
  • »23.12.03 - 05:56
    igracki
    > by FALCON1 on 2003/12/23 6:56:42
    > Look at MOS SDK....
    It only describes how to use tp from an own program and how one can check if its running.
    But I want to have a sort of a description for all the keywords in the printer driver (the *.tpp files in tp:printers/), cause its an ascii file, so I thought I could easily change some lines to adjust a current printer driver (hp deskjet 990, I read the psc 2210 is compatible with this) to be able to print with the psc 2210...
    Does anyone have a different email address than support@irseesoft.de to contact the turboprint developers?
  • »23.12.03 - 12:23
