autoconf outdated version on mossdk
    _ThEcRoW
    Posts: 298 from 2008/10/27
    I have been looking, and with the sdk installed, i see that i have autoconf 2.13, but have a confure script that says i need 250 or higher. Searching on the net, i saw a post on another forum saying that version 2.59 was released, and that post was from 2004?!?!?!. Could anyone explain that to me?
    Thanks in advance!!!
  • »20.04.11 - 20:09
    Posts: 2985 from 2003/3/5
    I don't have the time to update all those nix build tools. If you need something more recent, build it yourself - it's usually a matter of configure and make, sometimes smaller configure changes.
    [ Edited by jacadcaps 20.04.2011 - 21:35 ]
  • »20.04.11 - 20:35
    _ThEcRoW
    Can i compile that tools using the sdk in my mini directly?. Seems i have to get a look at the ppc bianries of linux.
    Thanks!!!
  • »21.04.11 - 13:56
    Yes, sure you can compile them with the sdk. How would ppc linux binaries help you though?
  • »21.04.11 - 15:47
