Mui structure question
    rebraist
    Posts: 96 from 2011/4/6
    I have this code taken from guru meditation net.
    I would like that the last two objects (simplebutton and stringframe) being on the same row. i read about the HGroup but i was no able to obtain anything. how can i modify it? Thank you
    app = ApplicationObject,
    MUIA_Application_Title , "Titre",
    MUIA_Application_Version , "$VER: 0.0.1 (05/06/04)",
    MUIA_Application_Copyright , "©2004, copyright et célébrité",
    MUIA_Application_Author , "L'auteur, c'est vous !",
    MUIA_Application_Description, "Description libre",
    MUIA_Application_Base , "DISKO",
    SubWindow, window = WindowObject,
    MUIA_Window_Title, "Projet DisKo : Premier programme MUI",
    MUIA_Window_ID , MAKE_ID('W','I','N','1'),
    WindowContents, VGroup,
    Child, TextObject, TextFrame,
    MUIA_Background, MUII_TextBack,
    MUIA_Text_Contents, "\33c Il affiche ici du texte multiligne
    dans un TextObject\navec une frame \33bTextFrame\33n",
    End,
    Child, TextObject, ButtonFrame,
    MUIA_Text_Contents, "\33c Et ici un TextObject avec une frame
    d'aspect \33iButtonFrame\33n\nce qui lui donne son aspect de bouton",
    End,
    Child, TextObject, StringFrame,
    MUIA_Text_Contents, "\33c Et un dernier avec \33uStringFrame\33n\n
    (Escape pour quitter l'application)",
    End,
    Child, SimpleButton("Bouton sans action"),
    End,
    End,
    End;
    [ Edited by rebraist 07.04.2011 - 14:16 ]
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »07.04.11 - 10:14
    Posts: 2449 from 2003/2/24
    Child, HGroup,
    End,
    End,
    End,
    End,
    End,
    End;
    Don't forget the extra "End,".
    Intention is way important when writing such long MUI-macros or you'll soon loose track into which group which objects falls.
  • »07.04.11 - 11:59
    Yomgui
    Posts: 348 from 2004/8/31
    @Kronos: "intention" ? :-D
    @rebraist: so yes, encapsulate two last children by this:
    Child, HGroup,
    End,
    Important for MUI dev: The 'End' is not needed because there is a 'Child', but because there is a 'HGroup'.
    As we can see, there is a 'Child' before SimpleButton without the need of a 'End'. Because SimpleButton is a closed macro, HGroup not
    [ Edited by Yomgui 07.04.2011 - 16:27 ]
    And now... next project!
  • »07.04.11 - 12:25
    rebraist
    Thank you!
    Let's see if i've understood:
    i have to close with an end every "object" described by tag list.
    1) app
    2) window
    3) groups
    4) gadgets
    Some macros don't need end because they "close" in them the tags needed.
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »07.04.11 - 19:41
    Krashan
    Posts: 1107 from 2003/6/11
    That's why I never use these messy macros... ;-)
  • »08.04.11 - 02:14
    rebraist
    Where can i find the list of all available "gadget" usbale with mui?
    I looked the autodocs but it only talks about the attributes of those objects (MUIA)
    Surely i don't know how to use properly an autodoc but i don't find both objects or methods.
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »08.04.11 - 09:23
    Posts: 3210 from 2003/3/5
    The SDK comes with AGuide formatted MUI classes docs, listing all included .mui and .mcc classes.
    SDK:Guide/Magic_User_Interface has all the info you need. There's also the inheritance structure described in mui.h for its built in classes.
    [ Edited by jacadcaps 08.04.2011 - 13:42 ]
  • »08.04.11 - 09:40
    rebraist
    thank you! i'm so excited because today have obtained a vgroup nested in a hgroup. I know it's a simple thing but for me it's a great goal!! :-P
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »08.04.11 - 10:20
