extracting video from vcd
    GMKai
    Posts: 253 from 2003/4/7
    What does it need to encode data from an (s)vcd to hdd?
    Is it possible to only take some parts?
  • »08.12.03 - 10:34
    hooligan
    Posts: 1948 from 2003/2/23
    Pretty simple really. Just copy the av file from cd to harddrive.
  • »08.12.03 - 10:44
    GMKai
    to make it more complex: ;-)
    cd is not visible on ambient.
    accessing cd0: through shell doesn't work either.
    and limiting capturing to parts of the video is not done too.
  • »08.12.03 - 12:40
    hooligan
    a couple solutions . I'll think more after you have discovered more problems :)
    - Copy the file using a pc and transfer via network
    - Copy file using pc, burn the file on an rw and take it to Pegasos
    - Forget the damn videocd :)
  • »08.12.03 - 12:55
  • jah
    jah
    Posts: 69 from 2003/3/24
    extract the data track with makecd and then you will be able to play
    that file with frogger or mplayer (only tested with frogger)
  • »08.12.03 - 12:55
  • elf
    elf
    Posts: 32 from 2003/5/24
    Try VCDSave (http://benderirc.de/xsvcd.html). If you can play videocd on your computer with frogger, vcdsave should be able to copy video track(s) from cd to hd, as they share the same direct cd accessing engine.
  • »08.12.03 - 13:38
    Jupp3
    Posts: 1193 from 2003/2/24
    Maybe you could read VCD track with MakeCD as imagefile and convert it to mpeg with vcdgear?
  • »08.12.03 - 14:27
  • Targhan
    Posts: 2833 from 2003/2/8
    To extract video from a (s)VCD to the harddrive from a CD that MOS
    isn't supporting the filesystem for, you'll need to have FroggerNG.
    Install FroggerNG, as per the instructions; then, you will need the
    application so aptly named, VCDSave!
    FroggerNG Page <- More about
    Frogger.
    FroggerNG
    Dowloads Page
    <- Find extra things, like VCDSave
    here.
    The included instructions should be enough to get the movie saved to
    the hdd.
    :idea:Targhan
  • »08.12.03 - 16:25
    GMKai
    thank you all so far, will come back later with more questions :-)
  • »08.12.03 - 16:32
