MMkeyboard and morphos
    Doraemon
    Posts: 137 from 2003/7/1
    Im trying to use the multimedia keys of my keyboard in morphos with the MMKeyboad.lha from aminet with no luck.
    Anyone tryed it?? Any suggestion???
    Thx4all
  • »04.12.03 - 22:53
    roschmyr
    Posts: 206 from 2003/2/20
    i mean MMKeyboard was only a hardware-hack for the
    amiga and amithlon.
  • »04.12.03 - 23:28
    Posts: 1516 from 2003/2/24
    MMKeyboard tool is not useful for Pegasos. You need more generic tool
    to access multimedia keys.
  • »04.12.03 - 23:31
    Doraemon
    You can sayme another tool to test????
    (PD:MMKeyboard runs in amithlon wih no hardware hack)
  • »04.12.03 - 23:53
    docgeddy
    Posts: 37 from 2003/7/31
    ask the author, Guido Mersmann, if he could do a MorphOS-Version. If enough people are nagging him, he gives up and finally makes it :-)
    DocGeddy
    Member of Butterfly Army
  • »06.12.03 - 10:07
    I recall MMKeyboard required software hack for Amithlon.
    What ever, why not check Aminet for alternatives? Maybe there is one
    that works (usually problem just is that they do not recognize new key
    codes).
  • »06.12.03 - 11:24
    bigdan
    Posts: 63 from 2003/4/12
    Try with an Usb keyboard and Poseidon (Trident) as explain in TotalAmiga 14.
    Otherwise you could try to edit a special keymap with the old "amiga classic good tool" KME : anybody test it ? The subject is interesting ;-)
  • »06.12.03 - 15:22
    KME works pretty well but its user interface is having problems in
    MorphOS...
  • »07.12.03 - 15:45
