PPC assembly debugger
    ausPPC
    Posts: 543 from 2007/8/6
    I would like to establish a bounty for a MorphOS PPC assembly debugger and it would be very helpful to know how many other people would consider contributing to it and also how likely it is that anyone could successfully complete it.
    I'm also interested in the discussion of how such a low level debugger would work on MorphOS. For instance, it would seem that the qbox | abox nature of MorphOS hinders an effective assembly debugger so, would something like a PPC interpreter be a sufficient 2nd best solution?
    Or do I have to commission a pci Action Replay?? Only joking. Sort of...
  • »27.10.10 - 22:50
    MarK
    Posts: 641 from 2004/1/25
    imo, the MorphOS assembly debugger is a MUST HAVE application, that (again imo) should appreciate every lowlevel developer!
    bye, MarK.
  • »28.10.10 - 12:36
    ausPPC
    Another odd idea - could running OS4 gdb through OS4Emu possibly work?
  • »28.10.10 - 12:41
