make vcds
    Doraemon
    Posts: 137 from 2003/7/1
    Hello, Im downloading a lot of films with mldonkey and I want to convert it from divx to vcd.
    I was testing a utility called vicado but I get graphic corruption in the gui. (Is normal?)
    I can make it with ffmpeg+vcdimager+makecd ut its really complicated.
    Anyone knows a gui or a easy way to make it??
    (Some time ago I seen a set of scripts to make it but I cant remember the webpage)
    (A example with the ffmpeg parameters and vcdimager will be wellcome to)
    Thx4all
  • »19.11.03 - 23:13
    poundsmack
    Posts: 1346 from 2003/6/8
    might not want to say where you are download movies or films from or that you are downloading them.......thats just asking for trouble hehe
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »20.11.03 - 00:06
