Bochs 2.0.2 starting error
    Coder
    Posts: 296 from 2003/3/5
    When I start Bochs I get the following error:
    Couldn't open the vga font
    Anyone got any idea what this is? I could not find any solution yet.
    Coder
  • »16.10.03 - 09:09
    tokai
    Posts: 1289 from 2003/2/25
    You have to copy vga.font and the vga-directory with the "16" file inside.
    e.g.
    copy mypartition:bochs/fonts/#? to SYS:Fonts ALL
    but the ASSIGN ADD should do the job too.
  • »16.10.03 - 11:58
    Coder
    Hi Tokai,
    Copy vga.font and the vga dir is indeed the fix. Don't know what I will end up in now but at least this error is fixed. Thanks!
    Coder
  • »16.10.03 - 12:13
    Coder
    Is there not some good MorphOS info about Bochs? Would make it easier. Next up in the line of errors:
    Unable to find ATA channel, ioport=0x03f6
    Coder
  • »16.10.03 - 12:24
    Coder
    @tokai
    you have creaded already a harddisk file?
    Nah. That must be it then. :-) In the coming days I will have a look at Bochs again. So many things to do and so little time.
    Coder
  • »17.10.03 - 19:53
