some MOS PUP benchmarks needed
    Posts: 1230 from 2004/2/8
    Hi there!
    I'm currently running some "real life" benchmarks to see how MorphOS performs on different configurations.
    Could someone please run a few tests on his MOS PUP config and post the results here?
    Here are a few that I've already done on my Efika:
    1. DigiRoller (both 68k and native version)
    - Speed test
    - Converting a given file (AKsack.DBM) to a .wav file
    (note: 68k emulation in DigiRoller for OS 3.x speeds up after 3-4 trials (at least in my case), so the results may differ - it's safer to perform at least 5 tests and then write down the best result).
    2. Converting the output .wav file from test 1 to mp3 using lame (again, the 68k 3.98.2d from Aminet (I used the 060+FPU version), and MOS native 3.98 from Aminet) using standard parameters.
    3. Counting how many seconds it takes to copy the output .wav file from test 1 to RAM and another HDD partition
    I've made some more tests. If someone wants to repeat them on his config then please let me know.
    Results (in Polish, but I think everything is quite self-explanatory) can be found here
  • »11.07.09 - 20:37
